Loading C4 and Five on Sky EPG without card | |
| Former member Join Date: 22-06-2005 Location: UK: Kent. Spain: Madrid.
My System: Sky Plus V3 TDS 470n, Pace 2600CI, Thomson Sky HD, Technomate 1000D, Prodelin 1.8m dish + Invacom Quad C120, CM feed, Lacuna/Wolsey V3 meter |
If you have a Sky receiver but don't have a viewing card, the Sky electronic programme guide (EPG) will not load Channel Four or Five, the default behaviour is to load BBC London, BBC2, ITV Central W, then Sky One, and so on, even though C4 is free to air. The way to get round this is to insert any card, such as a supermarket loyalty card, credit or debit card, or driving licence into the viewing card slot. Re- boot the Sky box by switching off at the mains, when it restarts, it will show default behaviour- 101, 102, 103, 106 etc. When the guide has fully loaded, take out the card and re- insert it. The Sky guide will re-load, but it will show the missing 104 and 105, as well as C4+1. The BBC and ITV regions associated with card the box was last paired with will instead be loaded, from the receiver's memory, in place of the default behaviour. (tested on Pace Sky+ V3, Thomson HD, Pace 2600 CI) * edit- if the debit or loyalty card is re- inserted the box will revert to the BBC & ITV regions on the card the receiver was last paired with, not from the last viewing card inserted, as I wrote earlier. Tested on two more receivers. A Pace 2600 CI standard Sky box behaves differently, it's not necessary to take the bank card out and re- insert it. Either way up will do, EPG from the last card paired will load* | ||
| | #4 | |||
My System: Sky Plus V3 TDS 470n, Pace 2600CI, Thomson Sky HD, Technomate 1000D, Prodelin 1.8m dish + Invacom Quad C120, CM feed, Lacuna/Wolsey V3 meter | Also works if you take it out and turn the card upside down. | |||
| | #5 | ||
My System: TM6800HD, TM1000, TM5200, TM2200 motor, Triax TD110 dish + Fibo 90cm. | Yes, and I got it from a post by Analoguesat on another forum But I have had a paired card in my receiver, so I have never seen the default behaviour, so wasn't able to test it fully. | ||
| | #6 | ||
| Regular Member Join Date: 29-12-2007 Location: Cornwall, UK
My System: Sky Freesat in UK, Astra 1 ana/dig in UK, Astra 2 South Beam in Spain. | Well you certainly fooled me snap, I thought it was genuine - until I tried it. Maybe I need a gold or platinum card for it work! | ||
| | #7 | ||
My System: TM6800HD, TM1000, TM5200, TM2200 motor, Triax TD110 dish + Fibo 90cm. | It is genuine I believe, as when I put a Tesco Clubcard in mine, it says Invalid card or similar, but without it I get, Please insert viewing card. | ||
| | #9 | ||
My System: Sky Plus V3 TDS 470n, Pace 2600CI, Thomson Sky HD, Technomate 1000D, Prodelin 1.8m dish + Invacom Quad C120, CM feed, Lacuna/Wolsey V3 meter | I can assure you it works, it's not April 1, you just have to follow the instructions exactly, re boot (this means pull mains plug out) with card inserted, press Sky guide on remote, take card out, re- insert and wait. I tried on three Sky boxes this morning and it worked on all three. I have a Sky+ with the full EPG loaded with a Boots Advantage card in the viewing card slot! (Not sure if I get any points, though) | ||
| | #10 | ||
| ASBO Club Member - Persona non grata Join Date: 07-10-2008 Location: Ireland
My System: sky digibox also U P C Ireland | Hi Snap, I also have heard this does work,I get F T V uk channels with a dark blue card(the is,t one issued by Digital sky) does not work for Me if I try The lighter(Yellow house)card.When My batty U.K Aunt visits our house She thinks I am trying to steal her Tesco points Lol ;-) | ||
| | #11 | ||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | What an excellent trick Snap - well done for documenting it. | ||
| | #12 | ||
| Member Join Date: 15-09-2008 Location: Ireland
My System: KAON KSF560 - 80cm dish - monobloc - 13E and 19.2 | sorry my box is paired to a ireland card now i dont have the card anymore i tried your trick it does not bring back the ch4 any help? | ||
| | #13 | |||
My System: sky digibox also U P C Ireland | Your 80 CM dish should pull them all in at Your location.U.K F T V card brings in all the B B C/Itv/4/ channels.Self tuning is another option. go to services,go to systym set-up,go to add channels, Then start at 10.715, H, S/R 5/6,go up by increments of 15&change polarity. You will find plenty of goodies at 2D F T A,You can add to Your extra Channels menu. A F T V card(If You have a friend in U K Will give You Much more,even a cancelled Sky card will give E4,more4 etc.Ch5 is still only available by manual tuning here. | |||
| | #14 | ||
| aka Skyman Join Date: 13-06-2003 Location: Limassol, Sunny Cyprus
My System: 3m(sky),1.8m(astr/hotbird),1m (nilesat)1m(arabsat)diseqc 4,sky plus,humax freesat,visionet 8000s,technomate 5400 ci+ usb super. Satlook nit colour + Horizon hdsm. wii ![]() | Are you sure E4 and more4 are free because I can't get it free although more4+1 on 139 is fta ? | ||
| | #15 | |||
My System: sky digibox also U P C Ireland | not F T A(free to air) F T V (free to view)needs a card issued in U.K even a cancelled Sky U.K card will still bring in F T V Channels A cancelled Sky card issued to Irish Republic will not unflag(unencrypt) F T V Channels such as E4 etc. no card needed to add the BBC/ITV Channels here to other channels. In Cyprus a much bigger dish& first class L N B would be needed. People with much more expertise than Me Can tell you exactly what You need.P.S If You are getting E4 I think it is down to date of card issue as well,as Channels that are unflagged often remain scrambled on older cards from what other people have told Me | |||
| | #16 | ||
My System: TM6800HD, TM1000, TM5200, TM2200 motor, Triax TD110 dish + Fibo 90cm. | Actually E4 and More 4 are both FTA on 10729V,22000 | ||
| | #17 | |||
My System: Sky Plus V3 TDS 470n, Pace 2600CI, Thomson Sky HD, Technomate 1000D, Prodelin 1.8m dish + Invacom Quad C120, CM feed, Lacuna/Wolsey V3 meter | There's nothing to stop you viewing Channel four on 10714 H for free in the 'other channels' menu. | |||
| | #18 | ||
My System: Sky Plus V3 TDS 470n, Pace 2600CI, Thomson Sky HD, Technomate 1000D, Prodelin 1.8m dish + Invacom Quad C120, CM feed, Lacuna/Wolsey V3 meter | | ||
| | #19 | ||
My System: 3m(sky),1.8m(astr/hotbird),1m (nilesat)1m(arabsat)diseqc 4,sky plus,humax freesat,visionet 8000s,technomate 5400 ci+ usb super. Satlook nit colour + Horizon hdsm. wii ![]() | Ah, that explains it. We can't get the verticals over here. | ||
| | #20 | ||
| Member Join Date: 10-01-2009 Location: Susssex
My System: Amstrad Sky box no card |
I put a debit card into my Amstrad box. Turned off the power at the wall. Turned back on and bingo Ch4 is there. No need to remove card again. Thanks. | ||
| card, epg, loading, sky |
