Sky reception for Barcelona | |
| Member Join Date: 22-11-2008 Location: Barcelona
My System: Kaon 570 |
Hello!! I'm new on this and I want some advices before I begin to buy things. My idea is to see Sky UK in Barcelona. I only have a Sat receiver Kaon 570. I asked to an installer and told me that for good reception of Sky I will need a 110cm dish, is it correct? I read that 90cm is enough, but maybe for a better reception 110cm could be fine. I know that I will need a pcmcia cam for the receiver, but I don’t know which want I need. When I have all ready, how can I subscribe to Sky? Thanks in advance. | ||
| Super Moderator Join Date: 07-05-2007 Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus V2, Thomson DSI6210 Sky+160, Thomson DSI4214, Gibertini 104cm, Invacom SNH-031, 12inch 36v Actuator, Technomate Vbox-II, TF5000CI, TM-5200D, Sling Media, Rover ST-4, Rover SDM-1s, 42E to 30W, Tecatel 1.35m fixed on 28e | Welcome to satellites, As far as reception goes, in that region, I beleive an 85cm is sufficient enough to catch 2d spot beam. I know a pal of mine set up a temp feed and had it on an 80cm but to play safe and cover rain fade, a 1Mtr + would be a wise option I'd say. | ||
| Former member Join Date: 22-06-2005 Location: UK: Kent. Spain: Madrid.
My System: Sky Plus V3 TDS 470n, Pace 2600CI, Thomson Sky HD, Technomate 1000D, Prodelin 1.8m dish + Invacom Quad C120, CM feed, Lacuna/Wolsey V3 meter | Most users say 90 cm is OK for 24/7 reception. You won't be able to get Sky using the receiver you have. It is possible with the right cam, but you have to return the card to a Sky receiver once a month or the card will go dead. You can only get this set up working if you have a legitimate working Sky subscription. | ||
| | #4 | |||
And how i can get a sky subscription? Is it possible? Do you recommend me that I buy a sky receiver? Thanks for the answers. | |||
| | #5 | ||
My System: Sky Plus V3 TDS 470n, Pace 2600CI, Thomson Sky HD, Technomate 1000D, Prodelin 1.8m dish + Invacom Quad C120, CM feed, Lacuna/Wolsey V3 meter | You will have to get a friend in the UK to organise one for you, or use an agent that specialises in subscriptions for mainland Europe. | ||
| | #6 | ||
Blog Entries: 4 My System: Sky+, DB 7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Yes and you will in the first instance need a Sky digibox to activate the subscription card. | ||
| barcelona, reception, sky |
