Have to disagree strongly with you Pedro on the last point, a LNBF (one- piece LNB) will never perform anything like as well as a good C120 LNB, for Astra 2D reception (this is what drives the need for large dishes) a LNBF will disappoint. A 1.8m fortecstar dish will never come anything like a 1.8m ASC/Andrew dish for performance. It's not just build quality, a 1.8m prime focus will always have lower gain than a 1.8m offset dish, owing to the laws of physics.
Invacom C120 Quad has been proven many times to give the best BBC & ITV reception on dishes larger that 120 cm. I've done many tests myself, and posted the results on the forum.
I have a an interest in a BBC &
Sky installation business in Madrid. My partner there will not use anything other than:
ASC/Andrew 180 dish, Invacom Quad C120 model QDF-031 and a ChannelMaster feedhorn.
There have been reports of people getting all BBC channels in the Alicante region on this dish.
I wouldn't recommend anyone getting a 240 cm ASC/Andrew or Prodelin owing to the cost.
ASC dishes are very easy to assemble and set up. They are so well- made they never distort in very high temperatures- in effect they are virtually indestructible. Prodelin dishes are very similar.
A number of places sell ASC/Andrew (Formerly channelMaster):
ASC/Andrew from Demon multimedia (you may have to wait)
_http://www.ciberland.com/
Prodelin from Tecatel (contact them to find a local dealer)
_http://www.tecatel.com/productoX.php?idp=816
Invacom LNB (currently in short supply) and Prodelin from Antnet Digital
_http://www.antnetdigital.com/en/
Feedhorn from:-
_http://www.satellitesuperstore.com/feedhorn.htm
Prodelin main page, e-mail to request more local dealers:
_http://www.tripointglobal.com/antennas.php
