poor Freesat in Alicante, Costa Blanca 2.4m Fortec Star dish
Old 30-12-2008   #1
Terrytoon's Avatar
My System: 2.4m dish zapbox twin 2 metronic. pc 2200amd 2gig ram
I am new to freesat, I have a 2.4m dish invacomsnh 031 lnb to a Metronic zapbox twin tuner. I live 40k south of Alicante and can only get BBC very weekly. No ITV etc.The TPs for Itv show no quality of signal. Any ideas?
Dish size edited. Admin
Terrytoon is offline   Reply With Quote
Old 30-12-2008   #2
Design Engineer/Installer
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions...
Originally Posted by Terrytoon View Post
I am new to freesat, I have a 4.2m dish .............
Well thats' a good start.. first dish and it's a 4.2m...
What make is the 2.4m dish?
pedro2000uk is offline   Reply With Quote
Old 30-12-2008   #3
Terrytoon's Avatar
Fortecstar, not a solid dish, but others are in use close to me.
Old 30-12-2008   #4
Robbo's Avatar
Real name: Mark
Is it 2.4m or 4.2m???
One of these, I presume:-
_http://www.fortecstar.com/estore/storefront/default.asp?ProductID=16&CategoryID=8
poor Freesat in Alicante, Costa Blanca 2.4m Fortec Star dish-16-1-gif
Old 30-12-2008   #5
Dazed and Confused Mod
PaulR's Avatar
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100
Oh dear, a Fortecstar.
These are not good dishes unfortunately and behave more like a 1.8m or even a 1.5m dish. They are very thin and distort easily when being assembled. Even if you manage to assemble it straight then a strong wind can easily bend it out of true. It sounds like your neighbours have their Fortecstars (assuming they ARE all Fortecstars) screwed together just a little better than yours.
Your best bet, assuming you don't have the option to start with a decent dish again, is to look at the dish very carefully for anything which is out of true. Take measurements across the dish and from the LNB to each side of the dish to see if you can make anything any better.
Actually, the first thing I would try with any dish is to rotate the LNB in its housing slightly each way to see if the skew is out. Skew can have a huge effect if it's not right. After that it's down to constant fiddling!
As I get older I find myself thinking about the hereafter - I go into a room and then wonder what I'm here after.
PaulR is offline   Reply With Quote
The Following User Says Thank You to PaulR For This Useful Post:
divibi (30-12-2008)
Old 30-12-2008   #6
Robbo's Avatar
Real name: Mark
Here's a thread to give you some clues:-
Fortec star 1.8m dish Ain't that bad after all / c-band
The Following User Says Thank You to Robbo For This Useful Post:
divibi (30-12-2008)
Old 30-12-2008   #7
Terrytoon's Avatar
I know these dishes are a prodlem, when I put the dish togeather I used lining pins in all sections to be sure to get rid of all hole tollerances, I have tried the skew, it is in the very best position. Assuming the problem is not the dish, although I accept it well way be, could the box be a bad choice? putting the dish togeather was not a problem, I am an engineer by trade.
Old 30-12-2008   #8
PaulR's Avatar
Yes, it could be. Best way to check, if you're on good terms with your neighbours, is to try your receiver round at one of their setups. If you can, double check by using a neighbour's known, good receiver on you setup.
Old 30-12-2008   #9
Terrytoon's Avatar
Typo 2.4m sorry
Old 30-12-2008   #10
What LNB have you got on it?
Old 30-12-2008   #11
Terrytoon's Avatar
invacom snh 031
Old 30-12-2008   #12
Robbo's Avatar
Real name: Mark
That LNB is for an offset dish with a F/D of about 0.6
_http://www.invacom.com/products/snh_031.htm
It won't work very well. You need a feedhorn and LNB combination designed for prime focus, with a lot lower F?D ratio.
Something like-
_http://www.globalinvacom.com/products/adjustablefeedhorn.php
and the 2nd one down on this page
_http://www.globalinvacom.com/products/dbssingle.php
although the quads are supposed to work better for fringe reception.
divibi (30-12-2008)
Old 30-12-2008   #13
Terrytoon's Avatar
Thanks for that, Maplins supplied that lnb with the dish, good eh
Old 30-12-2008   #14
invacom snh 031
I kinda knew it would be an LNBf ... The feed horn that is inside that LNBf will block out the outside of the dish so it only sees the middle 70cm-1m rather than 2.4m.. so you have a lot to gain...
If it was a cheapo (6 euro) LNBf I'd say pop it open and hacksaw the ali feed horn right off, seal it over the hole and later add a bit of a round plate (scala ring) where the holder is ..... but not on an invacom..
maplits? take it back if you can.. and bill them for the expense..(2 flights etc.. )
The Following 2 Users Say Thank You to pedro2000uk For This Useful Post:
divibi (30-12-2008), Terrytoon (30-12-2008)
Old 30-12-2008   #15
Robbo's Avatar
Real name: Mark
Yes, confusing.
The, 2.4m has an F/D of 0.38
However, Maplin are selling this, as a suitable LNB for that dish:-
_http://www.maplin.co.uk/Module.aspx?ModuleNo=97081
which has an F/D of 0.55 to 0.65
??????WTF
The Following 2 Users Say Thank You to Robbo For This Useful Post:
Old 30-12-2008   #16
Terrytoon's Avatar
OK, so my first step, as the lnb now has marks from attatchment etc, is to go to one of the local sat people and try to do a part swap for the correct lnb. The ones that I can see on other dishes are far smaller than mine, but according to a mate who has seen one in action, the reception is good. The owner has said is no BBC2. I cannot ask him myself as he is in UK.
Old 30-12-2008   #17
You couldn't photo some of those lnbs and upload them here could you Terry...?
Old 30-12-2008   #18
Terrytoon's Avatar
can do 2morow it is dark at the moment.
Old 31-12-2008   #19
Terrytoon's Avatar
not good quality,long range.
poor Freesat in Alicante, Costa Blanca 2.4m Fortec Star dish-hpnx0073-jpg   poor Freesat in Alicante, Costa Blanca 2.4m Fortec Star dish-hpnx0074-jpg   poor Freesat in Alicante, Costa Blanca 2.4m Fortec Star dish-hpnx0076-jpg   poor Freesat in Alicante, Costa Blanca 2.4m Fortec Star dish-hpnx0077-jpg
Old 31-12-2008   #20
Terrytoon's Avatar
The first of the lnbs looks like mine, but longer!
Old 31-12-2008   #21
Thanks for taking that trouble...
…at first glance .. they all look wrong.. (wouldn't surprise me too much) unless someone is supplying LNBf's with integral feed horns with an f/d ratio of c.38 not .6.
1# = quad or quattro Invacom .3 LNBf with an f/d of… .6
2# = quad or quattro Invacom .3 LNBf with an f/d of… .6
3# = quad or quattro ???? Very blurred but looks like another Invacom .3 LNBf with an f/d of… .6
4# = quad or quattro (not sure brand) LNBf with an f/d of… .6
All four should be the C120 LNB equivalents (quad or Quattro) with either C120 flanged (.38) matched feed horns or adjustable feed horns set at .38. Unless someone is making Invacom LNBf’ copies with f/d ratios of .38 or whatever ratio…
What they all want is one of them.. (the C120s)
_http://www.globalinvacom.com/products/dbsquad.php (Quad C120)
Or
_http://www.globalinvacom.com/products/dbsquatro.php (Quattro C120).
And one of them…
_http://www.globalinvacom.com/products/adjustablefeedhorn.php set to .38
They are all losing loads of signal and might as well have a smaller offset…
Maybe they are all set back of the focal point and that’s how the signal is getting in- still not right.
Some of the feed support arms don’t look 100% either.
mind you.. I've ad a few so could be all booze b#ll*cks
Anyone else want to play... guess the LNB…
The Following User Says Thank You to pedro2000uk For This Useful Post:
divibi (01-01-2009)
Old 31-12-2008   #22
PaulR's Avatar
Well..
No 2 doesn't look as though it's pointing to the centre of the dish to me!
Old 01-01-2009   #23
woborny's Avatar
My System: 1.8m PF Dish, most sky and freesat recivers, 80cm on Illusion motor and Dreambox DM7025, TDT
no 3 looks like an invacom c120 with feedhorn....the one you want for your "fortecs-argh" dish
it also looks like a famaval 2.4m dish, judging by the plastic LNB holder, and the angle that the support arms are...the support arms / poles also look different to the other 3 photos...
woborny is offline   Reply With Quote
Old 01-01-2009   #24
Other evidence on the blurred number three is it's the only one that isn't pushed so far forward to the shoulder.... as a feed horn would get the focal length too... the other three LNBfs probably can't get near enough to get the the focal point either - bizarrely that might help a little with a .6 on a .38 dish.. or not. The feed horn on 3 looks small though.
BTW .. Happy New Year all... ... and my head's still in 2008 ... where's that coffee...
Old 04-01-2009   #25
So what's wrong with this picture?
So what's wrong with this picture... answers on a postcard to ...
_http://www.maplin.co.uk/Module.aspx?ModuleNo=97081&TabID=1&QV=Y&C=EBook&U= Ecat
oh, and I like this ...
_http://ebook.maplin.co.uk/maplinlargeebook/enter.html?page=310
try clicking on the c120 with feed horn...
I wonder if that's why 4 fortec star 2.4s have ....invacom lnbfs...
24m, alicante, blanca, costa, dish, fortec, freesat, poor, star
