Box won´t hold Add Channels
Old 31-12-2008   #1
trigger's Avatar
My System: 30W,7W,13E,16E,19E & 28E Dishes everywhere Darkbox 2008HD Sly+ V3
Anyone know what causes a Pace DSN430 to loose any channels added to "other Channels" when the power fails.
Would I be along the right lines thinking its probably a faulty capacitor?
Triggs
trigger is offline   Reply With Quote
Old 31-12-2008   #2
guest
Posts: n/a
My DS430N doesn't lose the "Other Channels", but there is a long history of all sorts of Murdoch Boxes arbitrarily dumping them.
The tendency to do so seems greater when there is pressure on the allocated memory due to having quite a few Other Channels stored plus lots of programme reminders, auto views, series links etc.
Personally, I only have two "Other Channels" stored and don't make much use of the other features that fill up memory, so that might explain why I don't have problems.
Conversely, it is not necessarily the case that your own DS430N actually has an incipient fault.
Do you have lots of ITV Regions stored, plus lots of reminders etc?
Old 31-12-2008   #3
Design Engineer/Installer
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions...
I think they can all/most do that..
pedro2000uk is offline   Reply With Quote
Old 31-12-2008   #4
trigger's Avatar
No reminders set. If you put one channel in and power down then it disappears. Just really a pain because power cuts can be quite frequent here.
Old 31-12-2008   #5
guest
Posts: n/a
In which event, perhaps there is a specific fault after all.
How much of a problem is it?
Surely, apart from ITV Regions, there isn't much non-EPG stuff to be had these days?
Though I imagine having ITV Regions of all flavours is handy to guard against the ravages of marginal reception?
Old 31-12-2008   #6
satelliteman's Avatar
Real name: Paul
Should save. Is it running on the latest software although that wouldn't have any effect I wouldn't of thought.
Be suprised Rai when out of UK and out of 2d region, 12402, 12480 etc etc.
satelliteman.
An Installers Choice
Follow us on
add, box, channels, hold, won´t
