Sky breakup problems
Old 10-01-2009   #1
My System: Dreambox 7020, HH120 Discq notor with Triax 1.1m
I have had sky reception ok on an Amstrad box for several years. Lateley it has been breaking up especially on Virgin, Sci Fi and Eurosport.
I have changed the LNB but it is still the same, I thought that it could be the dish position but first tried it on a larger 1m dish and it still had problems. I tried a Dreambox and CAM and it could receive them but it still had some picture artifacts.
The question is, is there a problem with the transmissions from Sky or could it just be the Amstrad decoder (I did not think this because BBC/ITV etc are all fine).
Many Thanks
New2It is offline   Reply With Quote
Old 10-01-2009   #2
guest
Posts: n/a
No known problems with transmissions.
It is possible your cabling is degraded by physical damage or water ingress. This can show itself by giving variable results at different frequencies.
That said, you say you tried the Box on a different Dish - presumably that was on a different cable run rather as well?
Old 10-01-2009   #3
The two systems are on different cables which are roughly the same length (but go to different rooms).
I am trying to get a relatives box so I can try that as it may still be dish alignment (but I would have thought that the 1m dish on the Dreambox would be more than adequate for Sky test).
Old 10-01-2009   #4
guest
Posts: n/a
Could you tell us where you are located?
Old 10-01-2009   #5
Based in Sheffield, Uk. Problems started approx 2 months ago on a few channels but now spreading. Changed LNB to a new version a few weeks back and it made it better for most channels but now starting to get worse again. BBC always ok but Sky 1 etc very jerky and lcoking up with still picture but still sound
Old 10-01-2009   #6
satelliteman's Avatar
Real name: Paul
Could be outside intereference causing your problems, it's a possibility and not to be ruled out
satelliteman.
An Installers Choice
Follow us on
Old 10-01-2009   #7
rolfw's Avatar
Real name: Rolf
I would opt for the Amstrad giving up the ghost, possibly tied to slight dish misalignment.
Rolf
Old 10-01-2009   #8
aka Skyman
Zorba's Avatar
My System: 3m(sky),1.8m(astr/hotbird),1m (nilesat)1m(arabsat)diseqc 4,sky plus,humax freesat,visionet 8000s,technomate 5400 ci+ usb super. Satlook nit colour + Horizon hdsm. wii
Are Hallmark and sky sports extra also having a problem ?
Zorba is offline   Reply With Quote
Old 11-01-2009   #9
I don't have Sports Extra but Hallmark is certainly bad (breaks up and then says "there is a technical fault with this channel", to recover I simply move back t o BBC1 and wait approx 15 seconds).
Old 12-01-2009   #10
aka Skyman
Zorba's Avatar
Interesting because we have a problem over here with skysportsnews/extra, hallmark,eurosport2 and paracomedy2. All share the same frequency 12.148H and we suspect interference from Arabsat or Badr which transmits on the same frequency and we are under their beam.
Old 31-01-2009   #11
Just an update.
Took my Amstrad receiver to my sisters and tried it on her setup (which could get the channels I could no longer receive). Worked even there worse so even though the original problem had the symptoms of bad alignment/lnb it actually turns out to be the receiver (indeed when got it back home I lost some more channels and these reappeared as the unit was left on - possibly as it heats up).
breakup, problems, sky
