Here's what I Posted in reply "elsewhere":
If it is actually a
Sky Dish, then the LNB is positively located and can't be "misaligned" - unless the entire arm has been bent.
You should, however, check that the Skew is set properly (Usually at "3").
I think it is odds on that the Dish has been knocked out of alignment, but the fact that one feed works suggests it is only a small amount out and is "on the margin".
Therefore, as long as you take care, you should be able to correct this yourself.
If there is someone who can help you, get them to observe the Signal/Quality Bars and (without blocking the signal!) you gently push the LNB arm first one way, then the other, then up, then down.
You should be able to deduce from that which way to move the Dish - and remember it will be a matter of millimetres only.
