Reception problems in S Spain Ch4 E4 m&m ITV
Old 05-03-2009   #51
Former member
snap's Avatar
My System: Sky Plus V3 TDS 470n, Pace 2600CI, Thomson Sky HD, Technomate 1000D, Prodelin 1.8m dish + Invacom Quad C120, CM feed, Lacuna/Wolsey V3 meter
If you have bought the Invacom QDF -031 it will fit on any dish, offset or prime focus. The feedhorn for an offset dish is in the picture. I think you have said you have the dish in the other picture. If you have this dish, LNB and feedhorn, it will work perfectly.
Si el 'Feedhorn' es el mismo como la foto, es perfecto para una disco channelMaster offset. El LNB Invacom QDF-031 se adpata para todos los tipos de antena, offset, o prima foco. Foto nš 2 es ChannelMaster /ASC 1.2m x 1.35m offset.
Reception problems in S Spain Ch4 E4 m&m ITV-invacom-quad-w_cm-feed-png   Reception problems in S Spain Ch4 E4 m&m ITV-picture-7-png
snap is offline   Reply With Quote
The Following User Says Thank You to snap For This Useful Post:
pipino (06-03-2009)
ch4, itv, mandm, problems, reception, spain
