Huge difference between 28.2 and 28.5, what can i do?
Old 18-04-2009   #1
My System: Skybox
Hello everyone again.
In Altinkum- Turkey, i have a 5 metres dish and i can get signals from 28.2 without any problem(sometimes itv's signal go very low tho)
But i cant get any signal from setanta sport in night time. Its on eurobird 28.5. When i search the channels in the morning i can find channels from setanta but in night time no signal. Only 0.3 degree make a big difference.
What is ur advice to me? What can i do then?
summerbreeze is offline   Reply With Quote
Old 18-04-2009   #2
satelliteman's Avatar
Real name: Paul
It's due to the very narrow beam width of the dish. Alignment has to be peaked on one or the other, not a problem with a small dish of course.
satelliteman.
An Installers Choice
Follow us on
Old 18-04-2009   #3
Robbo's Avatar
Real name: Mark
Yes, the beamwidth of your dish is approx 0.36 degrees, so when focussed on 28.2, you will have less gain for 28.5. Perhaps some sort of actuator could be used to move the dish slightly when switching between the sats.?
Old 18-04-2009   #4
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4
Have you got the LNB skewed for Astra 2 or Eurobird 1. There's 7 degrees skew difference between those two.
Huevos is offline   Reply With Quote
Old 18-04-2009   #5
Amo Amas Amant Admin
Topper's Avatar
Eh
I think you are mistaken the satellites are only 0.3 degrees apart, how can the skew be more?
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 18-04-2009   #6
Topper mate,
Astra 2 is an oddity; it is skewed 7 degrees clockwise in relation to the equator.
Old 18-04-2009   #7
Real name: Paul
Not sure that info is correct
satelliteman.
Follow us on
Old 18-04-2009   #8
Robbo's Avatar
Real name: Mark
I believe him, SMM.
_http://www.ses-astra.com/resources/pdf/en-shared/technical_support/Polarisation_and_Frequency_Allocations_1_0_0.pdf
Not only is it just Astra 2, but Astra 1 and Astra 3 according to the document, all of them Skewed by 7.5 degrees.
Dishpointer agrees.
Old 18-04-2009   #9
Skew for London (51.5, -0.126)...
Dishpointer:
Astra 2A/B/D = -13.2°
Eurobird 1 = -20.9°
Satlex:
Astra 2A/B/D = -13.6°
Eurobird 1 = -20.86°
If you use a program such as SMW Link it calculates 28E seen from London as -20.9, yet if you go to SES Astra's site and download the support documents they list the skew for London as -13°.
Old 18-04-2009   #10
My System: Skybox
I have a quality sharp lnb i think it is 0.3 db. do you know any better lnb for getting better signals?
even we move the dish 1 mm, all channels go scrambled or no signal. it is very sensetive for where we are (altinkum-didim, 100 km north of bodrum)
I know a bar they have a dish like mine but they have no problem. they have both setenta and skysports. I heard they went to İzmir and bought an equipment and put in front of the dish but they dont tell me what it is..
another thing, i want to thank you all, u all are very helpful people.
I will check my lnb, cable and other equipment and i hope we find a way to sort this out
Old 18-04-2009   #11
Real name: Paul
See where your coming from now. The ease of installing in the UK, lol
satelliteman.
Follow us on
Old 18-04-2009   #12
Topper's Avatar
Well
Ok thanks for that Heuvos, it seems like a dumb idea to me as it immediately goes against all the principles of satellite transmission theory and makes it difficult for people with polar mounts and H-H setups in fringe areas. Folks in fringe areas would be better using the old fashioned lnb's with co rotors (whatever they were called) to get good reception on 28.2/28.5 respectively, I can though now begin to understand why my sky setup suffers a lot from signal fade on Eurobird when heavy cloud is building in the south East as the skew is a fixed preset amount with a sky dish but in reality the skew required for Eurobird is more than the preset .
I have to say though, re-reading that pdf file, I am still not convinced 100% why would they build in 7.5 degree offset as it would almost prevent them using the satellites in a westerly location unless it is electronically configurable
Show Your Support
Thank you.
Old 18-04-2009   #13
My System: Passion HD, Nova HD S2, 85cm Mesh Dish, Fortec Star Diseqc Motor, Diablo CAM, Sky+ HD, Selfsat H10D2, Hauppauge HD PVR
I was a fan of the magnetic polariser before the days of Universal LNBs. The abilty to set individual skew per channel was ideal for motorised systems. The skew of an all-in-one Universal LNBF is always going to be a compromise in my opinion. I find it best to tweak it on 1.0W on the TP's in the FSS range that have both H and V signals, e.g. 12607 V/H. I try to get both at the same signal quality as they should (in theory) be the same power. I use other double polarity frequencies in the range as a sanity check.
Ratchet is offline   Reply With Quote
Old 18-04-2009   #14
trigger's Avatar
My System: 30W,7W,13E,16E,19E & 28E Dishes everywhere Darkbox 2008HD Sly+ V3
I´ll go have a play with a couple of big dishes here tomorrow and report. Thinking about it now even with 5 pints of Magners on board, the few dishes I look after on Eurobird do seem to be skewed further round. Possisbly - maybe
Get back to you tomorrow
trigger is offline   Reply With Quote
Old 18-04-2009   #15
My System: Skybox
Well, the dish is 4 metre parabol dish (4 year old)
The LNB is Invacom 0.7 db flanch
and its not possible to watch ITV and Setanta at the same time. No way You have to pick 28.2 or 28.5 or buy another dish lol
Old 18-04-2009   #16
Real name: Paul
Originally Posted by trigger View Post
I´ll go have a play with a couple of big dishes here tomorrow and report. Thinking about it now...... even with 5 pints of Magners on board, the few dishes I look after on Eurobird do seem to be skewed further round. Possisbly - maybe
oh, have I missed the party
satelliteman.
Follow us on
Old 18-04-2009   #17
I don't see what you are getting at here. If later for some reason the satellite was required back in conventional orientation the stabilization system would be used for that, after all that is what is holding it at any particular angle.
Here that's very a well respected LNB, although no longer available.
Which dish? I thought you said yours was 5 metre with Sharp LNB.
Old 18-04-2009   #18
trigger's Avatar
Nah its the weekly Five on Friday - LOL
Old 18-04-2009   #19
My System: Skybox
Here that's very a well respected LNB, although no longer available.Which dish? I thought you said yours was 5 metre with Sharp LNB.
I am sorry. it is 4 metre and not sharp. I thought it was sharp and 5 metre but my mistake. i bought this equipment from a friend.
Old 19-04-2009   #20
Which Invacom is it? Can you post a photo? I've got a QDF-031 (C120-quad) on my dish but nothing to compare it to. All prime focus dishes here either have this LNB, an obsolete Sharp, or a modified Darkgold which are super sensitive but only single port.
By the way if you have a 4 metre dish and the bar has a 5 metre then the has 56% more dish surface which is going to make a black and white difference.
Old 26-04-2009   #21
kamaleon's Avatar
My System: skystar2 pci skystar usb + porty lidl camping dish maybe one day i'll have a dreambox 500s...
Hi Huevos,
Say what do you mean by modified darkgold? You mean the feed cut off? Got any pics of that m8?
Cheers
kamaleon is offline   Reply With Quote
Old 26-04-2009   #22
Originally Posted by kamaleon View Post
Hi Huevos,
Cheers
I was having a blonde moment. It's not a Darkgold, it's an Inverto Black Ultra.
Huge difference between 28.2 and 28.5, what can i do?-lnb4-jpg   Huge difference between 28.2 and 28.5, what can i do?-lnb5-jpg   Huge difference between 28.2 and 28.5, what can i do?-lnb6-jpg
Old 26-04-2009   #23
kamaleon's Avatar
wow just look at that, really strange mod!! Does that perform better than the inverto white tech C120?
Old 26-04-2009   #24
I haven't compared them.
This modified LNB is only available in a single. In a twin or quad install I'd use an Invacom, but for a single I'd choose this. C/N is brilliant.
I've been experimenting with my 1.5 metre dish lately. I removed the Invacom quad and the CM feedhorn and put a Darkgold single. C/N was marginally better according to my Satcatcher and I'm getting better quality on Astra 2D and have picked up a couple of extra transponders. Still only getting verticals though so can't say how they compare on horizontals.
Old 26-04-2009   #25
kamaleon's Avatar
So you're actually saying this lnb is actually sold like that? care to disclose more details?
I think you keep mistaking the inverto black ultra with the darkgold, which are completely different lnbs btw
282, 285, difference, huge
