Originally Posted by robw Hello All,
I am based in the North of Finland and have a SKY HD box with full channel package.
I have been having problems watching sky since the introduction of the new "Improved" TV guide function last week.
I have to unplug my box during the day (dogs) and when I get home EVERY channel says "No satellite signal is being received"...
I read on here over the weekend it could be due to a software update during the time the box was unplugged. So I followed the suggestion on Saturday to do s "Forced Software Download" by holding down the backup button on the box during startup. It worked on Saturday, but now when I have tried it during the evening after work it can take up to 4 hours until I get a channel to work!!
Any ideas what I can do, and could it be also due to the new cards issue?? |
The "No signal is being received" rerror on HD boxes after the new software upgrade is due to the fact that there is now an option in the software to configure the box to work on single feed rather than two feeds.
The default setting after the software upgrade is for two feeds, so if there is only one feed going into the box (or one of the feeds is not working) the box gives the "No signal is being received" error.
To correct this, you must go into setup menu by pressing services>001>select, then scroll to the bottom of the screen to the last option and configure the box to use single feed.
