Sky+ Input Signal not working
Old 28-05-2009   #1
My System: Sky+ Sky Multiroom Apple iMac
Hi everyone,
after a thunderstorm a couple of weeks back, I noticed that the Sky picture was breaking up a fair bit and I was getting the 'No Satellite signal Received' message a fair bit too.
As this seems to happen a lot, I took no notice, but after a few days we found a lot of recordings were failing.
I eventually found out that the Input 2 had no signal and was not locked. I assumed it was the Sky+ box, but when i swapped over the aerials, Input 2 worked fine and it was Input 1 that now had no signal and was not locked.
So the problem is obviously with the cabling or perhaps the LNB?
I haven't a clue, basically, so how do I go about diagnosing the problem, without first paying Sky £65 to come out and have a look at it?
We're still finding that the picture on the working Input is still breaking up quite a bit, but we also have Multiroom, and that is absolutely fine.
Cheers in advance for any suggestions.
redwin11 is offline   Reply With Quote
Old 28-05-2009   #2
satelliteman's Avatar
Real name: Paul
Could be either one of the ports on the LNb, cable itself or any connectors and joins in the downlead. Work back from the connector on the receiver to the LNb. Remake connections first, then try swapping ports on LNb to eliminate the other.
SM
satelliteman.
An Installers Choice
Follow us on
Old 28-05-2009   #3
SM
Cheers, I'll give it a go!
By the way, how do you disconnect the cables from the LNB?
Do they screw out?
Old 28-05-2009   #4
Amo Amas Amant Admin
Topper's Avatar
Well
Do they screw out?
Yes they should be connected with an F-connector
Sky+ Input Signal not working-fconnector-jpg
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 28-05-2009   #5
Perfect, cheers!
Old 01-06-2009   #6
Right, I swapped over the cables in the LNB and the second aerial into the Sky+ box still didn't work, so I imagine it must be the cable itself, or the connectors on either end?
So I take it my next step would be to remake the connections on that cable?
And if it's still the same, then the cable needs replacing?
Old 01-06-2009   #7
Topper's Avatar
Yes
It certainly is pointing towards that
Show Your Support
Thank you.
Old 01-06-2009   #8
Real name: Paul
Yes, try the connectors but also check to see if there aren't any joins in the cable run that have corroded (tape joins are a givaway)
satelliteman.
Follow us on
Old 04-06-2009   #9
I'll have a look tonight, thanks.
I take it I'd be better off getting a local repair man out than calling up Sky if I need a new cable? Or could I possible do it myself?!
Old 04-06-2009   #10
Real name: Paul
Yes, if your comfortable with ladders, you could tackle it yourself; it's fairly straight forward
satelliteman.
Follow us on
input, signal, sky, working
