Originally Posted by geoffreys Thanks for that. But would that require a monthly sub (or additional monthly sub) to SKY?? Then there is the problem of if I bought (where from?) a SKY HD box I'd have to have it matched to my SKY card, would SKY agree to that when it is already matched to my regular (SD) SKY box? Or would I have to obtain (from SKY??) a FTV/FTA card? Regards buying a SKY HD box I read on another thread that many were stolen and SKY won't recognise them for matching with cards. So, being in Cyprus, what is the best way to obtain a SKY HD box. Sorry to ask so many further questions, but I need to know the score, and costs!, before embarking down this route to obtaining Ch4 reception. I cannot receive CH4 SD because of a mobile phone (cellnet) TX on our roof.
Geoff |
Hi Geoff,
The
Ebay
route might be the best way to get your hands on a HD box, don't get a Thomson though as they are prone to psu problems. Maybe try this guy?
h**p://stores.shop.
Ebay
.co.uk/Specialist-Electronics__W0QQ_armrsZ1
Then when you get your new HD receiver simply ring sky up to match card and box. Ch 4 HD should be working anyway even without pairing. You must tell them you wish only to use the recording features of the box like a sky + and are not interested in the HD mix at this time. If you don't they'll switch the HD mix on and charge you £10 extra a month!
don't forget you'll need a second cable run from your lnb,
Sky HD as I'm sure you already know has two tuners.
regards
D.
