Audio Prob lems,on my Thomson Sky Digi Box,durable chirr sound?
Old 17-07-2009   #1
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband!
Hello!
since yesterday,my thomson sky box makes strange durable chirr sounds,when i watch a programm,between swtiching the channels,i here,i more intensive chirr sound,,and then durable chirr during watching the programm,any ideas,what could be fault?
Turok is offline   Reply With Quote
Old 17-07-2009   #2
Toute Ronde Bon Oeuf
Tivù's Avatar
Real name: Gordon
Exactly which Thomson Box is it?
There have been many instances in the past 3 years or so of strange faults stemming from premature failure of Power Supply Smoothing Capacitors.
That said, Audio chirps don't strike me as necessarily being related to that - Have you double checked all your SCART leads are properly seated?
Tivù is online now   Reply With Quote
Old 17-07-2009   #3
Turok's Avatar
Hi !
on the underside i read the type dsi 4212!
yes scart all okey,every other receiver works fine!
was only very intresting,on that day,the blue yellow house card stop working,the chirr sound will beginn first time!
thanks for your fast reply!
Old 17-07-2009   #4
Tivù's Avatar
Real name: Gordon
Hmm. That does seem too much of a coincidence - Have you tried power cycling the Box ie Disconnect from mains supply for a good few seconds then reconnecting it?
If there is some sort of glitch caused by the change in Card permissions (somehow!), then power cycling should sort it out.
Old 17-07-2009   #5
Turok's Avatar
yes i try reconect many times,the power,but no problem,i have a 2. sky box here from pace!
want only know,what could be fault inside,
i think the audi codec chip,or what ever
Old 17-07-2009   #6
Amo Amas Amant Admin
Topper's Avatar
Well
I have a Sony Sky box and whenever an update needs forcing through that is the sound that is made when watching programs. Do a forced update by powering down and holding the backup button, then power on again and hold the backup button until 3 lights come on front and message displayed (if using scart) do not switch off etc, then everything is usually fine again.
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
audio, box, chirr, digi, durable, lems, prob, sky, sound, thomson
