Magic Eye problems
Old 22-07-2009   #1
Rock39's Avatar
My System: Echostar DSB-808 Vi2 80cm Dish Motorised, temporally on a 1mt pole mount, (which tracks the arc if the wind blows the right direction.) Pace 2600 (Sky), Infinity usb+Cas3 programers. Dell P4-2.4ghz, 512DDR, 75GB HD Radeon 9800 Graf/Crd. + Ext HD M
Question Magic Eye problems
Can anyone one advise on the correct distribution amp to use for connecting two extra TV’s to a skybox – both controlled with magic eyes?
I have a coax from the RF output on my skybox which runs to my loft, there it joins with a second cable that returns the signal to second TV on the ground floor – this is quite a long run but everything works fine apart from some loss of picture quality. Wanting to boost the signal (& add the option of adding a second magic eye in another room) I added a distribution amp (I have tried 3 different ones now) however when using the amp I loose the ability to control the second TV with the magic eye control?
Documentation with the remote eye link states that coax from the R2 should be “in a continuous uninterrupted run” but I assume there must be some way to split\boost the signal & still control the signal with a remote eye? A split on the RF out to two magic eyes without any amp also stops them working…any ideas\info appreciated.
Rock39 is offline   Reply With Quote
Old 22-07-2009   #2
Grimm Member
rick1980's Avatar
My System: 1.1m Triax Motorised 45e-45w, Raven 60cm fixed, Fortex Zeta PVR, Technomate TM500
_http://www.screwfix.com/prods/69457/Electrical-Supplies/TV-Range/Amplifiers-Distribution/Labgear-HDU681-S-Home-Distribution-Unit-8-Way
I have installed a couple of these and they do the business, they come in a 6 or 12 way as well. They will also allow connection of a TV ariel with masthead amp, and a DAB ariel and fire it all down the one coax line.
I've booted up, I've patched in, I'm online, offline, downloaded and extremely cheesed off!
rick1980 is offline   Reply With Quote
Old 22-07-2009   #3
rolfw's Avatar
Real name: Rolf
Look at _http://www.tvlink.co.uk/acatalog/tvLINK_Amplifiers.html first item, can be powered by the 9v from the Sky digibox. I presume you've switched it on in the installers' menu?
Rolf
The Following User Says Thank You to rolfw For This Useful Post:
Rock39 (28-07-2009)
Old 24-07-2009   #4
Rock39's Avatar
Thumbs up
Thanks - have ordered the distrubition amp you mentioned, will report back when I get it installed!
Yes.. setup ok in the installers' menu, hopefuly this will do the trick..
Cheers,
Old 28-07-2009   #5
Rock39's Avatar
Thumbs up
All good!
Ordered a 4 outlet amp to leave the option of adding extra sets if needed – works fine, assume the issue was with a powered amp conflicting with the 9v from the R2 output….anyway thanks for the help.
eye, magic, problems
