Originally Posted by JMW I have just had a 1.9m Portugese Dish installed with an Invacom quad LNB. BigSat BS-S 501 XTRA receiver box. The dish is white not grey (I hope it is the Portugese Famaval as I specifically asked for that make). The reception of the following channels is either non existent or very weak: All on Astra 2A 28.2E - Channel 5 & CBBC 10773 H 22000, BBC2 10803 H 22000, Film 4 10714 H 22000, and other channels on these frequencies. Should I be receiving these channels along with such as Fiver and a few others or not? I don't have any channels tuned in on Astra 2D should I be able to receive on this as well? Thanks |
the Astra 2ds horizontal frequencies, that carry BBC2,3,4, CBBC, film4, FTA Five etc are very very weak on the costa blanca. you will not get these 24/7...even on a big 2.4m dish.
if you are north of Calpe your reception of these 2d H's is good from around 2am til 6pm...
if youa re south of alicante, then these signals are good from about 6pm til about 12 am
(these are very approximate as they all vary with dish type and lnb and receiver!)
not all the hype about famaval dishs is true. i have a nonfamaval 1.8m dish, and had the two side by side and tested them and the non famaval dish outperformed the famaval dish by over 1/2 and hour for the astra2d Hs!!
