Different compression on time-shifted channels?
Old 25-07-2009   #1
My System: na
I recently noticed that the file size of a recording from the comedy central extra +1 channel was a lot smaller than expected so I did a test a recorded the same program from comedy central extra and the +1 channel an hour later (and on two receivers as well; DM7020 and a DM8000). The result was that the '+1' files were a lot smaller (940MB on +1 and 1240MB on the main channel). Also, an editor I used to process these files displayed a lower average bit rate.
Can anyone confirm if the +1 channels do indeed have a higher compression? And if so, are all time shifted channels like this?
Thanks...
khcon is offline   Reply With Quote
Old 25-07-2009   #2
Superkomanda
bite's Avatar
My System: 0.8W; 4.8E; 13E (90cm dish), 19.2E; 28.2E; 36E (110cm dish), DM 600 + HDD (120 GB)
Well, Comedy Central Extra +1 just have smaller bitrate, than the main channel... That's all...
bite is offline   Reply With Quote
Old 25-07-2009   #3
My System: na
That's just my point...
A time-shifted channel is supposed to provide the EXACT same data (a different station logo being the ONLY difference), just an hour (or whatever) later. If they use a higher compression for these channels they are useless.
Where / how do I find out if this is really the case?
Old 25-07-2009   #4
Grimm Member
rick1980's Avatar
My System: 1.1m Triax Motorised 45e-45w, Raven 60cm fixed, Fortex Zeta PVR, Technomate TM500
A time-shifted channel is supposed to provide the EXACT same data (a different station logo being the ONLY difference), just an hour (or whatever) later. ?
Who says they are supposed to provide the exact same data? All they advertise is that the programming is 1hr behind. I suppose you could email the channel providers and ask on a out of interest basis.
I've booted up, I've patched in, I'm online, offline, downloaded and extremely cheesed off!
rick1980 is offline   Reply With Quote
Old 25-07-2009   #5
My System: na
It's implied...
Old 21-09-2009   #6
My System: Compro VideoMate S350 + Violet Phoenix card reader, DVB Dream v1.4i p1 + NDSCam v.0.0.0.7
It's implied...
Well not really, all a timeshift channel does is show the content from an hour ago etc. They don't have to have the same bitrate or resolution, in fact to get the +1 logo onto the screen they have to go though another encoder just to overlay that.
In a recent live episode of Big Brither's Little Brother a swear word was broadcast, while on the +1 broadcast the section where it happened was replaced with a message.
Take Virgin1 is 704x576 resolution, while Virgin1+1 is a poor 528x576 but both seem to have the same bitrate of about 3.4mbps
cragllo is offline   Reply With Quote
channels, compression, timeshifted
