Originally Posted by Jezza22 I can report exactly the same.
Excuse the ignorance but is there a way round this? Cant seem to get Five or any channel relating to it to appear in other channels.
I am on Costa Blanca east coast Spain 70k south Valencia.
Thanks. |
hi jeremy...
you should have access to the other three versions of FIVE on 12422H on your dish - as I can get the on my 80cm dish ATM - and I'm less than a KM away from you!!!
On your
Sky remote control:
Press Services
Press 4
Press 4
Type in the Frequency of
12422
H
27.5
2/3
And go to Find CHannels and Press Select.
On this frequency sites the other 3 FIVE regions.
Press the Yellow button and you wil place a TICK next to the top FIVE.
Press Select - and you get the channel line up complete.
You have now added a
Sky card, strong signal FIVE to your Other Channels list.
To access this Press Services, and go to your Other Channels list and select FIVE.
Note if you have a
Sky+ or
Sky HD box then you will not be able to record any of the channels in your Other Channels list.
Or get a sky card that is registered in another regional area!
