Javea isn't the worst, Alicante is. In Javea on a 2.4 you can receive horizontals for part of the day, in Alicante you can't. The Famaval dish works fine and is what 80% of people with 2.4 metre dishes have. I've never seen a CM dish here on the Costa Blanca bigger than a 1.8 metre, but the gain for the 2.4 metre CM should be the same as the Famaval. If you want a bit more gain from the Famaval you can add the extender panels which make the dish 3.1 metres, almost doubling the dish capture area. It won't get you horizontals 24/7 but you'll be able to watch them for a few hours longer than everyone else.
For verticals only a 1.8m should be fine. Here in Alicante my Gibertini 1.5m and Inverto Black Ultra work ok for 2D verticals with pixelization on some transponders after midnight. |
