Picture freeze - 3rd SKY+ box
Old 01-09-2009   #1
Real name: Mark
My System: Sky+ box connected to a Samsung lcd television via SCART lead
Help, very new member without a great deal of tech knowledge but I'll try and give as much as I can.
SKY+ box :
Thomson model 129e163, version 4E2139 with operating system version 1.31B07
This is connected via SCART lead to my Samsung lcd tv
My fault is that on certain channels ( Sky1, Sky2, Sky Sports 1, Sky Sports News, DMAX, Sky Movies 1 that we've noticed) the picture freezes anything from 6 to 33 seconds.
The system has been in place for 2 weeks and SKY have been very helpful, so far, replaced the SKY+ box twice and the LNB once, system rebuilds, resetting LNB without success.
During the Man U v Arsenal match on SKY Sports 1 recently during the second half 45 mins it froze 47 times accounting for just under 9 minutes of lost picture. When the engineer came out the LNB was replaced and the SKY+ box replaced for the third time but he basically said there wasn't much he could do as interference could be coming from anywhere, up to 30 ft away.
Is it true that nothing can be done as I am frustrated at paying for a service that I may not be able to recieve in an adequate level when every minute or so I lose 15 seconds of storyline.
Mark
ukspace is offline   Reply With Quote
Old 01-09-2009   #2
Manic Midlander Moderator
nanochickin's Avatar
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription
Are there any trees near the dish?
I've sen this before where certain channels are ok but others play up when the dish is slightly obscured by the branches.
The other thing i need to ask is if you have a DECT cordless home phone?
If you have try switching both the handset and base unit off as its not unheard of these phones knocking out certain channels
The only other thing to try is borrowing a friends Sky box and plugging it in to see if the same problem exists. You could also try your receiver at a friends house
I would take everything a Sky engineer says with a pinch of salt as most of them (well the ones round where i live anyway) are mindless idiots who haven't got a clue what they are doing and generally give proper satellite engineers a bad name
Nano
Sanity is nothing more than an excuse to be boring
<<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>>
<<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>>
<<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>>
nanochickin is offline   Reply With Quote
Old 01-09-2009   #3
Real name: Mark
Okay, quick reply
No trees obscuring dish.
I did read about the phone which I have switched both phone and base unit off without success.
Is every channel on a different frequency - as we speak I can add Discovery to the list of freezing channels.
Old 01-09-2009   #4
There are usually more than one channel per frequency
What sort of quality & power levels are you getting.
You'll find it in the services menu
Old 01-09-2009   #5
Real name: Mark
Quite good I think:
Input 1 Strength about 75% with quality of 90%
Input 2 Strength about 75% with quality of 80%
Both Lock indicators OK
Old 01-09-2009   #6
With the exception of Sky 1 all those channels are on horizontal polarity.
Sky 1 ireland is on Horizontal but Sky 1 UK is a vertical You do have the UK package dont you?
This might sound stupid but have you tried swapping round the cables from the dish. Sometimes it works
It would be a good idea to switch the box off at the mains before you do this
Failing that i would say its an lnb fault at a rough guess
Simple to fix. You'll get a new one off Ebay for about £5
Cheaper than getting one of the monkies from Sky out for an extortionate fee
Old 01-09-2009   #7
Real name: Mark
Bravo 2 is also freezing. I should hope to have the UK version, I'm in Kent.
Would the cables being round the wrong way not effect all channels ?
Old 01-09-2009   #8
It may be that one port is failing on the lnb
For general viewing the box only uses one lnb input for viewing and the other for recording
swapping them round can sometimes help find the fault
If the general viewing is better from the other feed that identifies the problem.
If it does fix the problem i wouldn't bother recording anything until the issue is fully rectified
Old 01-09-2009   #9
Real name: Mark
Okay now that is interesting. Obviously the recording of the football was still jumping as are the pictures I am actually watching.
When I playback a recording such as the football that jumps I don't see a 6 second pause, the picture simply jumps over it. I would see the clock indicating 67 mins 30 seconds and then 67 mins 38 seconds without the actual pause in playback.
I'm not sure what this would indicate but both input lines appear to be affected. Would this be interference of the recieved signal rather than a dish or box fault?
Old 01-09-2009   #10
Give Robbo on the forum a shout, He operates around Kent. Think you need somebody that knows what they are looking for to diagnose the problem
It could be caused by a multitude of things which you are'nt going to find unless your there looking at it. I've said all the things i would have checked.
I probably would have found the problem quite quickly if i was there with my meter. I think Robbo is your best option at the moment, either that or calling out the muppets from Sky again
Old 01-09-2009   #11
Real name: Mark
Thanks Nano.
Will check back tomorrow if he's online
Old 01-09-2009   #12
Real name: Mark
I've been on the members list and he's not listed as being contactable. How can I get in touch with him unless there's other people with any additional checks I can do.
Otherwise it may be a further SKY visit.
Old 01-09-2009   #13
rolfw's Avatar
Real name: Rolf
Have enabled your PM.
Rolf
Old 01-09-2009   #14
Robbo's Avatar
Real name: Mark
Thanks Rolf, have replied to PM received.
Old 07-09-2009   #15
Real name: Tony
My System: sky+
Mark, Any chance you can keep me posted as I'm experiencing exactly the same probs. Had the box replaced and engineers out to check signal but still picture keeps freezing on sky sports, movies & others. Thanks.
tmead is offline   Reply With Quote
Old 14-09-2009   #16
Real name: Mark
Have got the Sky Regional supervisor due out tomorrow with an engineer to run through some more signal checks with the possibility of moving the dish around the property.
The last visit resulted in the SCART lead being changed desite the fact I believe it to be a signal input fault.
The regional supervisor thinks it could be microwaves interfering with the signal and if so will get referred to a group in Southampton ! ! ! ? !
I'll keep you all posted as to what happens.
3rd, box, freeze, picture, sky
