Astra2d / dish size help - sweden
Old 16-09-2009   #1
My System: skydigital box 60cm dish sweden
help!!
What dish size?
can i use an offset dish? or must it be prime focus?
? i have full signal and 90 % quality on a 60cm offset using sky box missing and itv and bbc 1
keithdee is offline   Reply With Quote
Old 16-09-2009   #2
satelliteman's Avatar
Real name: Paul
Moved your post tagged onto a thread well over 5 years old.
Reports vary from 1.2 to 1.5m depending on exact location. Local knowledge is always best.
satelliteman.
An Installers Choice
Follow us on
Old 17-09-2009   #3
My System: TiVo & Sky/Astra 2D on a 1.8m Andrews dish. Canal Digital on 80cm fixed dish. DM800HD and DM500 on both dishes.
Hi Keith,
Whereabouts in Skåne? I live near Eslöv and a 1.8m Channel Master works great. A 2.4m Fortec Star, however, worked abysmally. Size is only one part of the equation, you also need quality too.
There is some info about my install here.
Feel free to ask away.
kitschcamp is offline   Reply With Quote
Old 19-09-2009   #4
Skybox Helsingborg Sweden
I took some photos hope this helps
I get no signal on bbc 1
I can watch BBC news
And i have 90 % signal quality signal strenght is 100%
Using a pace SD Skybox with a new sky freesat card.I even called sky to activate it my self which they did.
cheers
Astra2d / dish size help - sweden-dsc_0785-jpg   Astra2d / dish size help - sweden-dsc_0786-jpg   Astra2d / dish size help - sweden-dsc_0787-jpg
Old 19-09-2009   #5
Real name: Paul
The signal screen in picture one shows signal strength for transponder 4 being on the North beam.
satelliteman.
Follow us on
Old 19-09-2009   #6
Yeah, the Sky "help" page for tuning only uses one transponder. BBC News is also not on Astra 2D, so doesn't help you at all with knowing how likely the rest is.
Astra 2D needs a good quality large dish, a good LNB and feedhorn, and very careful and accurate alignment. Fail on any one of them, and you can forget evenings watching Strictly Come Dancing.
astra2d, dish, size
