I am shopping for kit to enable me to pick up Astra 2D from central eastern France so that I can watch the free to air BBC and ITV channels.
My receiver will be a Humax Foxsat PVR.
I think I will be buying this 85cm aluminium Gilbertini offset dish.
_http://www.satshop24.de/cgi-bin/satshop24/iboshop.cgi?show810,893470961175234
Would the Invacom TWF 031 C120 LNB be suitable for use with this dish?
Also, apart from the wall bracket or pole, cables and F connectors, do I need any other parts (e.g. to fix the LNB to the dish) or are the necessary bits included?
Reason: Live link deactivated - SM
Thanks. Are you saying that all standard LNBs are basically the same, then?
I take it that the one I quoted in my previous post is not a "standard" LNB but is intended for some other kind of setup.
I was told by someone else that I had to make sure the LNB was the "right one" for the dish, but that's not very helpful when you don't know what qualifies an LNB as the "right one".
The type of LNB you need, a universal, happens to be the most common type so you shouldn't have a problem obtaining one. Leroy Merlin, Weldom etc will be able to supply. Even Aldi (or was it Lidl?) have had them from time to time.
A C120 LNB has a different way of attaching itself (a circular ring) whilst the offset dish you are going to buy has a 40mm collar. A C120 LNB also needs a seperate feed horn, the type you need has it built-in.
The Following User Says Thank You to PaulR For This Useful Post:
Just realised that I had forgotten to tell you to make sure that you get a Quad LNB. This an LNB with four outputs. Your Foxsat PVR neds two of those as it has two tuners - the other two are spares for use in whatever room you want.
If you count up your receivers and find that you need more than four feeds then Octo LNBs are also available with - yes, you're way ahead of me - eight outputs. They are rather heavy though so the dish might need slight adjustment if it is set up with a lightweight single output LNB to start with.
