hello , i saw this and wanted to reply
the dish is of good size.
how long is the cable and how old is the cable.
if the cable length is not to long the cable should be good low loss as well.
the center conductor should be 1.13 mm and not the .95 or the .75.
too much loss.
are you geting the signal on a clear day and on bad weather loos it?
for the cost of the line amp about 10 to 15 euro i would try it.
place the amp by the satellite dish and try one first.
if it works you will need one for each line for each receiver.
if the cable is old and brittle or if the line is not low loss this will cause the weeker channels to not work and the stronger to work fine.
hope this helps
ralph
