Fine Tuning 1.2M Dish - Madrid, Spain
Old 15-10-2009   #1
I've just installed a 1.2m Andrews and 0.3 invacom quad combo in Madrid, but would appreciate any direction on getting the best out of it.
I aligned it initaly based on a Dishpointer.com LOS guess, which gets me 99% AGC , however differnet transponders are giving me different Quality and BER readings, I'm using a DM800 with about 3m cable, so I'm trying moving a little by little left and right up and down etc, but getting mixed results.
I've tried on 10818 (Which I think is the frequency for BBC London, i think I read this was the hardest to get ) the best I can get is about 46% and 2000 BER, 7.00pm at night so not so bad, but then if I switch to other tranponders they seem to drop down to 30% or less with higher BERs !
Is there a Transponder I should be using to fine tune the alinging, sorry if this obvious, I couldn't find anything in the forums using a search.
Phill
Flipit is offline   Reply With Quote
Old 15-10-2009   #2
Toute Ronde Bon Oeuf
Tivů's Avatar
Real name: Gordon
Moving the Dish is only a part of it: Have you tried adjusting the LNB both in terms of Skew and of position relative to the focal point of the Dish?
Tivů is offline   Reply With Quote
Old 15-10-2009   #3
satelliteman's Avatar
Real name: Paul
Hi, you need to consider the difference in received signal strength from each satellite across the 28e slot. Astra 2d beam for example is tightly focussed on the UK and from a quick search on the forum, requiring a 150cm -180cm for 247 reception in your region. This maybe where your confusion lies.
Careful dish alignment can only be carried out using an alignment meter and normally peaked on the weaker transponders. In addition 2d horizontal transponders can be weaker to receive.
satelliteman.
An Installers Choice
Follow us on
Old 15-10-2009   #4
Tivu: Scew and focal point I thinkare ok as I've got the single to go from 20% to 46% varying this.
Satelliteman: Yeah just couldn't fit a 1.5-1.8m so had to compromise, I went for the best dish and lnb I could find recommened at 1.2m. (I think..) so I know I'm gonna lose some early hours and evening, which is probably destorting the set-up given I was try to align it at 7:00pm my time. Would trying to get the best signal on a 2d horizontal be the best approach ? I just don't have access to an alignment meter other then the DM800 SatFinder. I have all the channels tunned already as I did it of anoth dish in the UK and saved the profile, so I'm not worried about trying to run the auto tunner, just tehe balance on picture vs the limitaion of the 1.2m dish. Ta
Phill
Old 15-10-2009   #5
Real name: Paul
Alignment on 2D transponders is recommended. This is where an alignment meter can help as all signal measurements can be seen as you make careful adjustments to the dish and LNb/skew. Sure this thread will be seen by some of our local members who may be able to offer more help.
satelliteman.
Follow us on
Old 4 Weeks Ago   #6
My System: 1.3m dish Panasonic Digibox Load of headaches getting channels
dish size
The dish is too small.
We just about get away with 1.3m in cadiz, you need a much bigger one in Madrid.
at least 1.5m+
petert74 is offline   Reply With Quote
12m, dish, fine, tunning
