Technical question about Grundig GDS 300
Old 05-07-2004   #1
T_G
The Consumate Dreamer
T_G's Avatar
Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything.
Muhuhuhahahahahaaaaarrrgggh
First Problem: When I see a movie it is clearly visible that the picture is clipped on both sides. This is visible because it cuts the names of the actors etc. I tried all the settings for the picture such as 16/9 etc, but no help. Anyone got an idea? It is not the TV either, because the same program will be fine when using my Dreambox receiver on the same TV.
Second Problem: When using the remote you can scroll to see the programs that are coming later. If you press select you can add a program to the schedule. The problem is, that some while ago I could press select, and then the menu for the personal planner opened and I could select "Auto View" and "Series Link". For some strange reason this is no longer the case. It only will mark the program, but I cannot add the other options.
Don't know why....
Third question: For these boxes, is there a software update one should make once a while with a forced upload through the satellite?
I know this is an old dog of a receiver, but.....
T_G
I only believe stuff that comes straight from Mr. Horses mouth!
T_G is offline   Reply With Quote
Old 05-07-2004   #2
rolfw's Avatar
Real name: Rolf
The setting should be letterbox T_G, works fine on the other Grundigs I've used.
You can always try a forced update, but if you can see the default transponder, you should be uptodate.
The autoview feature may not now be available with the FTV cards.
Rolf
Old 05-07-2004   #3
Super Minty Mod
PoloMint's Avatar
My System: 1200cc with 100,000,000,000 neurons and 100,000,000,000,000 connections
Our Panasonic 30 changed its option from saying 'letterbox' to '4:3L' in one of the more recent software upgrades.
I have noticed before that when some of the options change the box initially does something other than what it is claiming to, selecting a different option, saving it, then re selecting the one you want sometimes sorts it. Might be worth trying an output you don’t want then reselecting letterbox to see if it clears it.
'All you need is duck tape and WD40; if it moves and it shouldn't, use duck tape - if it should move and it doesn't, use WD40'
PoloMint is offline   Reply With Quote
Old 23-07-2004   #4
T_G
T_G's Avatar
Forced update? Is this the one wherer you pull the plug, then press on the off button while re plugging it?
T_G
Old 23-07-2004   #5
rolfw's Avatar
Real name: Rolf
The backup button on the receiver and keep it pressed until all of the lights flash.
Rolf
300, gds, grundig, question, technical
Similar Threads
Comparison between Grundig GDS3000 and Panasonic DSB30 Andrew Steel Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 6 05-05-2004 10:54 PM
complete noob question, sorry ! Ellis Dixon Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 8 21-09-2003 01:37 PM
Question Mark Fardelli Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 1 18-08-2003 11:00 AM
grundig s300 thomo Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 5 20-07-2003 05:14 PM
Small Question about recieiver fruitbat Digital systems 3 10-07-2003 08:10 PM
