Only a personal recommendation, but I would get my LNB from
Ebay
and my cable and clips etc from
_http://www.tlc-direct.co.uk/Main_Index/Cable_Index/Cable_PF/index.html
Check cable specs if you go elsewhere. All coax is NOT the same.
Your LNB must be for a $ky minidish and have either two or four outputs. I'd go for four, and then you have a direct upgrade path to $ky plus if required in the future.
Make sure you blank off and/or waterproof all your LNB connections with something called
self-amalgamating tape (also available from TLC and other good retailers). It's a waterproof rubbery-type tape that bonds to itself over a period of about an hour to form a proper waterproof barrier.
