Famaval 2.4 Extension Petals - advice please
Old 24-10-2005   #26
bignick's Avatar
My System: 3.1m Famaval on 28.2, 1.5m offset on 19.2e, 13e & 7e all mixed in a spaghetti of wires and going into a dream thingy.
Thanks for the feed back guys - its all useful stuff.
Yes, the dish and petals are a different colour Simon & and I'm relived to see you have the same issue with the satlook. I haven't mastered the satlook to the point that I see the real worth of the spectrum and span settings. I understand its useful for getting skew bang on i.e. making the height/depth of the hills and valleys as big as possible but I'm even having difficulty with that - I usually set skew by A1 eye!! Does the reading on the side (usually in the 60dbuv range) actually mean anything? I've found the only reading of real use to be the SNR reading on digital!
The final fit of the petals was such that both me and Chris reckoned that the dish looked spot on with no warping at all.
As for the channels - I will ask the customer to check these channels at the time you mentioned. We were checking the BBCs and ITVs mainly. We know that BBC Scotland and N.ire were both ok and they usually go quite early! I have to go back there as the photos taken on my phone camera were....well,
crap really!
Thanks for the extra pics zorba – there’s a dish next to the paphos dual carriageway just getting into Limassol that looks to have the same setup. Now I know what it looks like without becoming (more of) a danger on the road as I squint to see it!!!
Thx
Nick
bignick is offline   Reply With Quote
Old 24-10-2005   #27
satmaniac ,DIY man
maniacop32's Avatar
Question to zorba
nice view .is it a village in limassol district?
maniacop32 is offline   Reply With Quote
Old 24-10-2005   #28
aka Skyman
Zorba's Avatar
My System: 3m(sky),1.8m(astr/hotbird),1m (nilesat)1m(arabsat)diseqc 4,sky plus,humax freesat,visionet 8000s,technomate 5400 ci+ usb super. Satlook nit colour + Horizon hdsm. wii
Not my installation but a place around Apesia.The name of the village may have been changed to protect the innocent.
Zorba is offline   Reply With Quote
Old 24-10-2005   #29
satmaniac ,DIY man
maniacop32's Avatar
nice
i bet thats your previous dish .is it?
Old 24-10-2005   #30
aka Skyman
Zorba's Avatar
No thats still 7 floors up in limassol.If there is one thing worse than putting these extensions together,its taking them apart and putting them together again somewhere else.
Old 24-10-2005   #31
aka Skyman
Zorba's Avatar
I dont think its upside down,we were advised once to do it that way ,but i cant remember why.
Old 26-10-2005   #32
bignick's Avatar
Hi all
Finally got the pics
will post as soon as I work out how to do it
Cheers
Nick
Old 26-10-2005   #33
satmaniac ,DIY man
maniacop32's Avatar
bignick and maniacop 's first famaval with petals
Here it is.For some reason that only nickknows he could nt upload them.
Famaval 2.4 Extension Petals - advice please-famaval1-jpg   Famaval 2.4 Extension Petals - advice please-famaval2-jpg   Famaval 2.4 Extension Petals - advice please-famaval3-jpg   Famaval 2.4 Extension Petals - advice please-famaval5-jpg
Old 27-10-2005   #34
I do dishes,me.
simonskyman's Avatar
My System: big dish,sat box thingy,colour tv.and a remote control.
Not bad,boys.
Whats the focal length,the feedhorn looks a bit high.
Ps Dodgy stand
simonskyman is offline   Reply With Quote
Old 27-10-2005   #35
aka Skyman
Zorba's Avatar
So how much did it cost in the end?And is it 24/7 ?
Old 27-10-2005   #36
bignick's Avatar
Wink
We set the focal length to 93cm in accordance with an earlier post though to both me and chris we thought it seemed close to the end of the feed horn, but you can't argue with the tape measure!!
PS Dodgy stand? Please explain? I thought it looked ok, in fact I was impressed by the way that it could take 8 rawlbolts instead of the standard 4. I always smirk when I hear people talking about the size of concrete base to use then give no thought as to how they connect it to the stand. This one seemed ok especially if compared to the ones that trigger is supplied with - the footprint of the base seems too small to me - if you think of the dish as a sail then the elements (ie wind) has a greater mechanical advantage on the smaller base. I can see why he goes the extra mile and covers it in concrete.
Zorba - The first night the customers said it was good all night. A couple of days later they said they had experienced a little pixelation which is a little concerning. I've already discussed with chris to go back as the signal weakens somewhat and fiddle with the lnb using simons most ingenious plan with removing the petal. I feel in Ypsonis they should have 24/7 BBC at this time of the year..........still, not a bad first crack wouldn't you say?
As for cost....well....guess
Originally Posted by simonskyman
Not bad,boys.
Ps Dodgy stand
Old 28-10-2005   #37
I do dishes,me.
The base of the stand looked flimsy,especially the cross part,but those extra bolts are helping otherwise the stand would wobble,with the extra size dish now,more wind area.But thats why you have the tension wirw.
Old 03-12-2005   #38
trigger's Avatar
My System: 30W,7W,13E,16E,19E & 28E Dishes everywhere Darkbox 2008HD Sly+ V3
Just thought I would post you some pictures.
In my earlier post I mentioned concreting the base and that it gets a bit windy here. Have a look at some of the pictures of why I think they should be concreted in - especially when hurricane Delta comes to town!!!
The first two are of a dish that sustained damage even though it had a base fitted (not very well though). In the second picture you can see where the dish and base "walked" across the roof. The picture is taken from where it should have been.
The third picture is of a dish that got hit by a flying pergola off a local bar.
Happy Days
Famaval 2.4 Extension Petals - advice please-img_0247-jpg   Famaval 2.4 Extension Petals - advice please-img_0245-jpg   Famaval 2.4 Extension Petals - advice please-img_0239-jpg
trigger is offline   Reply With Quote
Old 03-12-2005   #39
bignick's Avatar
How windy did it get Trigg? The one that 'walked' - I take it it wasn't bolted down to the roof and was relying on the wieght of the base.
GREAT PICS!!!!
Cheers
Nick
Happy Days
Old 04-12-2005   #40
trigger's Avatar
Official figures state 95kph but it was much much windier than that - especially in gusts. Quite a lot of damage here. You can see on the first pic i think that the dish has bent around the 12 fixing bolts where it fixes to the mount. I'm sure i read somewhere that Famaval quote 160KPH as survivable speed - but not sure so will try and find out.
Xmas has come early for me as had 57 call outs on the first day and lost count since.
Too right about the builder not putting the steels into the roof. The base was essentially free standing. Muppet!!
Old 13-01-2006   #41
bignick's Avatar
Thumbs up
Hi guys
Myself and manicop went back out to this dish recently to re-finetune it as the owner rekoned he lost some channels at about 2300L. We reset it using Simons petal removal idea....... worked a treat!! It helps that we are starting to understand how to get the best out of the satlook now. I'll phone the guy back in a day or two just to make sure its gone ok but we both felt there was a massive improvement and it was ssssooo much easier with the petal out of the way.
Cheers
Nick
It seems you did a good job if it works all night.Well done guys.What about 8-10am?
Does ITV Yorkshire(10.891H) work after 7 pm?And ABC1 (channel 281).
I just started using the satlook recently(because i lost my roversat) and i cant get the "4th light" on or s/n readings,bloody annoying so i rely on the spectrum and span reading.
One other tip is to take off the bottom petal so you can get closer to the dish and adjust lnb for final readings without disturbing the dish,then carefully put petal back.
As for not been in line,I had that problem on a couple of dishes but not a big deal as long as the final shape is not warped,you can tell by looking at the dish from a side ans bottom view.do you have the old beige dish and new grey petals?The grey dishes have a slightly different edge that fits better to the petals.
Old 13-04-2008   #42
My System: installer
Google translation
Greetings to all, it seems that this antenna is a rare beast in any paraboloide the focal point optimum is determined by the diameter and depth, apart from the mechanical problems, the numbers add up to 240 cm but not at 310 cm. Not .....
saludos a todos, parece que esta antena es un bicho raro, en cualquier paraboloide el punto focal optimo esta determinado por el diametro y la profundidad, aparte de los problemas mecanicos, los numeros cuadran a 240 cm pero no a 310 cm. no se......
Please post in English, or at the very minimum, include a translation. Admin
virado is offline   Reply With Quote
Old 13-04-2008   #43
My System: amstrad 550 1.3 mtr dish
petal attach
hi trigger
i live in fuerteventura
can you fit petals to a std sky dish i.e 1.3m
to make it bigger
regards
simon
Originally Posted by trigger View Post
Find attached the pictures
Note this dish was installed in the morning and the concrete base was due to be done in the afternoon. Normally I would recommend doing the base first but it's football this weekend and everyone is in a rush!!
Pic 1 - Shows all 3 ties to the ground
Pic 2 - Close up of how cable is attached to back mount
Pic 3 - Close up of what we call a "Turnbuckle". As you turn it, it tightens both ways (left hand thread on one side and right on the other)
Pic 4 - The downward stay - funny angle I must admit - Different guage wire but it was all the local supplier had left!
Pic 5 - Note the bolt in the middle of the mount. We drill and Tap the mount and put a bolt in each side because we have found the mount will still turn on the pole no mater how tight you do the 3 bolts.
Hope this all helps
Let me know if you need more info, pics etc
Triggs
fuertesport is offline   Reply With Quote
Old 14-04-2008   #44
In order that the focal point continues being the same 93 cm, the depth of the disc tendria that to be more or less 65 cm if so changes the value of the f/d to 0.300 Someone can confirm the profunidad of 65 cm?
Old 14-04-2008   #45
bignick's Avatar
Perhaps the info at the end of this post will help: My 2 dishes in Cyprus
Hope that helps
Nick
Old 14-04-2008   #46
Bignick thank you for your help
not seen the post before, right i was thinking the f/d it is 0.300 an angle of lighting is needed of at least 150 º not to leave of the dish because then we catch noise and if it is this way and with the extensions it is obtained 2db more (he,she) means that with 240 and the same focal distance and the same horn feed illuminates out of the parable? Or probably there is a small difference of 0.5 cm in the position of the conversor between(among) 240 and 310?
Saludos
Old 19-09-2009   #47
My System: 2.4 Dish. Home built quad core Computer
Hi
I live on the Costa Blanca have a 2.4 Famaval Dish installed to our community of 50 Properties and looking to possibly extend the dish to 3.1 by way of Petals to better improve BBC2 and Ch5. We have free to air channels. 2 questions:-
1. Where might we be able to purchase the Petals from & at what sort of cost??
2. Has any one else had similiar thoughts for same reasons and did it help??
Regards
johnreynolds is offline   Reply With Quote
Old 19-09-2009   #48
woborny's Avatar
My System: 1.8m PF Dish, most sky and freesat recivers, 80cm on Illusion motor and Dreambox DM7025, TDT
the petals may not make the channels become available 24/7 but depending where exactly you are they will increase reception of bbc2 for maybe about an hour or two only. expect to pay around 400 euros in spain for the petals
this has been discussed before on here for the costa blanca....
Famaval panels 2.4 dish
best get the company who installed the dish to do the petals, if you were satisfied with their work!
woborny is offline   Reply With Quote
advice, extension, famaval, petals
Similar Threads
System advice needed harrisuk Digital systems 1 22-06-2005 04:30 PM
newbie looking for advice on equipment please vasques101uk Adult satellite channels 5 19-03-2004 08:12 PM
Conax + tita advice, please stratosg Conax, Cryptoworks, Nagravision, NDS and Others 1 11-02-2004 10:57 AM
advice needed rob43 DISH SETUP: Single sat, Multi-Sat & Motorised systems 10 30-11-2003 01:40 PM
New box advice cjgall Sky+ (Plus) and PVR Systems 15 18-11-2003 04:15 PM
