Originally Posted by trigger Such a Nice guy that Zorba - Can't wait until the ""expert"" next seeks advice.
Sorry I can't help you as we don't get that problem here, but I'm sure someone else will.
Good Luck |
I didnt call me an expert Trig,i cant even spell specialist contributor,the moderators gave that name to me.
Actually my question was put to Iceman,I just wanted to know if anybody knew how to do it,but its not a secret.
If you go into the New installation(services 4,0,1 select, 6) and proceed on to where it says "now scanning please wait",disconnect your satellite cable from the digibox.Then you will get the message NO DEFAULT TRANSPONDER FOUND,PRESS SELECT TO MODIFY SETTINGS.Then type in your chosen frequency etc,then press select and you will be shown the signal level screen.Now connect the sat cable and wait for the grey bars,then press select to continue.Then you will get CHANNEL LINE UP COMPLETE.
Now every time you go to default transponder it will be the one you chose,and most digiboxes will remember this after power is disconnected,some even after weeks of no power.
Mines a Keo.
