Since i am involved in the conversations here i will wright also!!
Yes it is true that i changed a few lnbs on big prime focus dishes and had a very good result with the quad invacom lnbs with a special adjustable feed(The adjustable feed makes the difference on balancing all the transponders)
2.7m dishes along the Limmasol beach work fine.Going up towards Pareklissia and Ayios Tyxonas FORGET IT!
From Pissouri towards Paphos 2.7m work fantastic(In Paphos you dont even need the Quad lnb.The single is fine!
I have also put a couple of those lnbs on 2.4m dishes with extensions and were ok but that also depends how the flaps have been put! That becomes 3m and not 3.2m
My friend ICEMAN hasnt got a problem since he has a 4.2m dish
Any questions i will be happy to help!
Best regards
longridge
