Best Digiboxes for Fringe reception
Old 10-10-2005   #76
iceman's Avatar
My System: 3.0m Motorised Channel Master 4 fixed dish SKY_HD DM7020s Vsat Kathrein UFS-910 HD
Originally Posted by bignick
Hi
[color=black]For me tuner sensitivity is measured in results!
I agree M8....good tuner is the one that delivers where others faill on the same setup..
@nopfusch
I am no expert on technical figures just an installer..Being an installer i get the chance to test different receivers on different setups...on this thread we simply discuss comparison between different Skyboxes performace from personal experiences..
iceman is offline   Reply With Quote
Old 11-10-2005   #77
Then maybe we should put some "technical figures" to the recievers we know to be good in fringe reception...
makum101 is offline   Reply With Quote
Old 12-10-2005   #78
[QUOTE=nopfusch]Hi there,
Paging through of some specifications, I found that -65dBm is an ordinary tuner sensitivity. A -70dBm input sensitivity is a lot better and the highest input sensitivity I ever read was -78 dBm. And the lowest -60dBm.
Of course, to round-off the judgment of a tuner is stability and picture and sound quality, which is not so easy to define in numbers.
Nopfusch,
Could you tell us which receivers have these specifications?
Perhaps then we could compare performance against Sky digiboxes and see if the difference in input sensitivity is significant or not.
Thanks.
Andrew
Andrew Steel is offline   Reply With Quote
Old 12-10-2005   #79
My System: sAT.: EechostarDVB 1000Ci2 (no 7 tears old and faulty), one Analogue receiver threshold -3dB, even older but still in good working order, 3.6m mesh dish with positioner, California feedhorn with mech. polarizer and C- and Ku- Band LNBs. PC1 P4 2.2GH
Hi to all interested,
unfortunately, not all manufacturers state the tuner specification in full either on their sales pamphlet or in the manual. In the latter you find the specification in question under Tuner. I attach three samples. But the support sections of various manufacturers should give an answer about that vital parameter of a receiver, if that spec’ is missing. I contacted in the UK a company to enquire about the input sensitivity of the tuner of a product and received promptly the answer.
The manufacturer state usually a range, e.g. -25dBm to -65dBm. Reason: if a receiver receives a very strong signal, you see nothing. If you in center of a strong footprint with a big dish, the tuner 'blacks-out', I have been told. I have seen it on TV sets (terrestrial reception) but not on satellite receivers. Therefore -25dBm. The other limit is of course for us of more interest. But we cannot verify if that receiver really handles a weak signal of -xxdBm. And that’s why it is important to talk to someone, who has in fact worked/experienced that receiver to confirm a good reception.
It would be interesting if the forum would allow list of receivers (with brand & model name), where everybody here can enter his receiver model and the tuner sensitivity, (if given in the spec's) plus experience with other relevant comments. e.g.
ABC receiver model EFG, tuner –25dBm to –65dBm
HIJ receiver model KLM , tuner –25dBm to –65dBm.
I stay at 21 south 3 west. Satellite XYZ eastern hemisphere beam is at my location with 34 EIRP. I can receive that signal with ABC receiver any time, with receiver HIJ only at night time 0:00 to 04:00 local time. Frequency, polarisation, SR, FEC.
Or similar.
The manufacturer can’t really just put a figure in the tuners sensitivity. They know, they could be challenged. Therefore I don’t need to buy a suppliers half stock, to select a sensitive receiver. I can do some pre-selection, just as I would only buy a receiver with mechanical (and magnetic) polarizer control only.
regards
nopfusch
Best Digiboxes for Fringe reception-tuner1-jpg   Best Digiboxes for Fringe reception-tuner2-jpg   Best Digiboxes for Fringe reception-tuner3-jpg
nopfusch is offline   Reply With Quote
Old 12-10-2005   #80
I wanted to separate the two items (from my previous post):
anyone with exeprience with a Manhattan PLAZA ST 500 on weak / fringe reception? I need polarize control and a good tuner. But the tuner is only -25dBM to -65dBM.
nopfusch
Old 23-10-2005   #81
He, why is sudden silence around here?
I’m busy to collect the tuner spec’s from the receiver mentioned in this thread. But for some I don’t find even the webb address. So please send me the web address from ‘your’ receiver, if you want to know the input sensitivity of the tuner in your receiver.
Regards
nopfusch
Old 23-10-2005   #82
Amo Amas Amant Admin
Topper's Avatar
Red face Hi
Well yes it does seem quiet in responses although I am sure it is nothing personal. Many people are not that interested in the manufacturers claims... they do not always hold water in reality. They prefer to use it in anger and find the best. If it is of any interest my ID digital states the standard -25 to -65 dBm and here is another reason why not many replies, although some do have more than one digital receiver, many including myself do not thus are unable to establish any baseline for comparison.
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 24-10-2005   #83
thanks toppervte33h
I discovered at Kathrein and Hirschmann receivers another measurement unit in µV (micro Volt). See the reply below - very fast reply, questioned Sunday evening, very good Steffen & Hirschmann, thanks.
> die Umrechnung lautet: the conversion is:
> 1 dbµV = -109 dbm
> 0 dbm = 109 dbµ
> z.B. 44 bis 84 dbµV = -65 bis -25 dBm
e.g 44 to 84 dbµV =
-25 to -65dBm. Note the dbµV have no minus sign.
> Es grüßt Sie freundlich With friendly greetings
> Steffen W....
> Service Center
> Hirschmann Automation and Control GmbH
> Hirschmann Competence Center
Old 04-11-2005   #84
My System: technomate 1500 ci super 80 c m dish diseque 1.2 superjack motorised system dragon celebro cas 3
triax dvb 2000 t cheap and yes it has built in modulator
llss is offline   Reply With Quote
Old 21-11-2005   #85
iggy's Avatar
My System: PrimeFocus 180cm (Astra 2D), MABO 115x128 (80E - 30W) , Kathrein ufs910, Amstrad DRX400 SKY Digibox+ Freesat card.
Panasonic DSB31
I have an opportunity to buy Panasonic DSB31 but before i go for it i will have to know if is it any good for fringe reception. Please post back asap
rgds
iggy
iggy is offline   Reply With Quote
Old 21-11-2005   #86
iceman's Avatar
Although i dont have personal experience with DSB31,i have heard they dont have a good tuner & are not suitable for fringe reception...
Old 21-11-2005   #87
aka Skyman
Zorba's Avatar
My System: 3m(sky),1.8m(astr/hotbird),1m (nilesat)1m(arabsat)diseqc 4,sky plus,humax freesat,visionet 8000s,technomate 5400 ci+ usb super. Satlook nit colour + Horizon hdsm. wii
Actually the tuners are not bad,but they have a software problem where they freeze up when going through weak channels or tv guide.They also have an overheating problem.Not recomended.
Zorba is offline   Reply With Quote
Old 21-11-2005   #88
devonbrown's Avatar
My System: 4 systems. In Scotland Sky with Pace 2600C1. In Costa del Sol 1.3 meter offset with Inv quad 0.3 LNB with pace 2600C1. In Algarve 1.5 fixed Inv Quad LNB with 4 Pace 2600C1 also 80cm dish with Inverto 0.2db monoblock LNB 4.8E/1W and TM_5400C1+ USB
I have just put an ad in for a Pace 2600C1 if you are interested
devonbrown is offline   Reply With Quote
Old 21-11-2005   #89
iggy's Avatar
Thank you all guys, i have already forgotten of that offer and look for something else instead.
Old 23-11-2005   #90
iggy's Avatar
Guys i need very quick answer - Pace 2200 what is this worth?????? I can get it for 10 quits.
Old 23-11-2005   #91
bignick's Avatar
My System: 3.1m Famaval on 28.2, 1.5m offset on 19.2e, 13e & 7e all mixed in a spaghetti of wires and going into a dream thingy.
Yeh, You're not being seen off. They're worth that and they have good tuners for Europe.....but they are sssssooooooo slooooowwww it's almost painful. Hope that helps
bignick is offline   Reply With Quote
Old 23-11-2005   #92
iggy's Avatar
Thanks. There is another thing that concerns me. According to some sources there are 2 different models in the same box labeled with 2200. The difference is that early model has better signal treshold but later one is not recommended. Have you got any idea whether it is true or not???? If so how can i distinguish between those 2 ?????
Old 23-11-2005   #93
bignick's Avatar
Sorry mate I don't know about that one. Are you sure they don't mean the 2500? The only 2200 I've ever seen are black in colour.
Old 23-11-2005   #94
iggy's Avatar
According to this source http://www.heyrick.co.uk/ricksworld/...x/intuner.html they come in one box. Perheps we have the same situation here as with Grundig GDS310. Still this is exactly the same box but they have different parameters. If you look round the back you will recognize which version you deal with by the last digit of model number. for example 310/2, 310/3 etc. Thats why i was wondering if Pace boxes had the same type of marking.
Old 23-11-2005   #95
bignick's Avatar
I dunno really. I know that the 2500 has a poor reputation however I have only ever seen the dark coloured version - the S4. I have to say that I think that it has been given a bad rap. Whilst I wouldn't make it a first choice box, I donot think it is all that bad out here in cyprus. Now I have NEVER seen the light coloured one out here - I assume for good reason!
Never seen the site you mention before. Its quite good, but avoid the dsb-30. A recent software update has rendered them all but useless in fringe areas.
Old 23-11-2005   #96
iggy's Avatar
Anyway i am in a huge dilemma because it's not common to buy Skybox on local Ebay especially for this symbolic price. I think i'll take that risk and buy this receiver. If any of you have some experience with that box, please let me know what to expect from it.
Old 23-11-2005   #97
iceman's Avatar
I wouldnt say they are useless in fringe areas...OK they lock up if the signal is low but work perfectly ok on 4.2m dish...
Old 23-11-2005   #98
bignick's Avatar
I see your point but they are terribly annoying when you have a dish that brings in certain channels at certain times of the day, it means you have to know exactly when those channels are off limits. Every single person I know who had one of these receivers have now gone over to Pace. Shame really, they were head an shoulders above all the other stuff in their day and if the glitch hadn't struck they would still be the box of choice!
Old 23-11-2005   #99
rolfw's Avatar
Real name: Rolf
Originally Posted by nopfusch
thanks toppervte33h
> 1 dbµV = -109 dbm
> 0 dbm = 109 dbµ
e.g 44 to 84 dbµV =
> Steffen W....
> Service Center
Sorry, only just noticed this conversion, but as far as I was aware, the conversion was 0 db/millivolt equalled 60 db/microvolt., not as mentioned above http://www.maxim-ic.com/appnotes.cfm/appnote_number/808
Rolf
Old 24-11-2005   #100
iggy's Avatar
Guys, i've just been sent a photo of that Pace receiver and it turned out that it wasn't model 2200 but 2400 in fact. Is this model any better or even worse?????
digiboxes, fringe, reception
Similar Threads
What is the Sky+ 2 like for Fringe reception pjij Sky+ (Plus) and PVR Systems 10 12-02-2008 04:36 PM
Digital Terrestrial (Freeview) TV reception, Aerials! spiney Members' input on FAQ and How To's 0 09-06-2005 03:05 PM
New Viewing Cards and old DigiBoxes DJHinett Receiver software, international Section 1 06-01-2004 06:29 PM
Bad reception on Channel U (Sky 467) solara Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 5 05-01-2004 01:29 PM
