FREESAT for BARCELONA
Old 05-10-2006   #1
My System: freesat in BCN using amstrad drx100 to astra 2 sat.
hello all
this is my first post and i'm about to go up on my terrace next week and try to set up my freesat thingy:
heres what i got:
Amstrad DRX100 skydigibox
coaxial cable
1.0 Metre dish
cheap finder
compass
tripod pole
instructions to set it up 28.2 degrees east of south
14mm drill and bolts for tripod
here's what i dont have:
an LNB (which one is best? duo, quod , bod , sod?)
a freesat card (i'll get a brother to apply and send it from uk)
if anyone can give me any more advice or tips that would be helpful.. then when i've set it up i'll make my notes/photos available to any in BCN.. deal?
FMCS
Last edited by FMCS; 05-10-2006 at 09:07 PM. Reason: cant spell..(i'm a product of thatcher's britain)
FMCS is offline   Reply With Quote
Old 05-10-2006   #2
Site administrator
Analoguesat's Avatar
Have a look at www.satelliteforcaravans.co.uk which is chock full of useful info.
Analogue forever!
Analoguesat is online now   Reply With Quote
Old 05-10-2006   #3
rolfw's Avatar
Real name: Rolf
The choice of LNB will depend a lot on the dish type, but if it is a bog standard 1m offset dish, then you should get good results from an Invacom, Inverto, Sharp or MTI Blueline LNB.
Rolf
Old 06-10-2006   #4
Dumb Satellite Babe
Satslut's Avatar
My System: Technomate 5500CIP Force 1145S Pace 2600 SS2 pci & USB Channel master 1.8m 1.2m & HH motor AMD 64 bit, Linux & Windows XP2
I am just across the water from you and a 1m dish just won't do it if you want to view in the evening, in winter the signal stays for longer, but not much.
Satslut is offline   Reply With Quote
Old 06-10-2006   #5
Hi
You should be fine with almost any lnb if you have a 1m dish. I am near Tarragona (about 80km SW of BCN on the coast) and have no problems with an 80cm dish, I get all BBC etc with no problems even in rain, I do use a Pace 2600C1 which seems to be the most sensitive receiver but I would imagine that the extra dish area of a 1m is going to get over any reciever sensitivity issues.
For lnbs you should be able to pick up a sharp or MTI in one of the local Satellite shops but I use electonica china online
_http://www.electronica-china.com/
very cheap and great service, I am using the edison 0.2dB lnb (7€ + Vat!)
Set up is easy enough if you are patient but be prepared for a lot of fine tuning to get the BBC channels coming in strong.
All the best
triplerotor is offline   Reply With Quote
Old 06-10-2006   #6
rolfw's Avatar
Real name: Rolf
Hi triplerotor, can you add the details of your reception and equipment to the Astra 2D dish size survey map please, as we have no info on there for Barcelona at present.
Rolf
Old 06-10-2006   #7
Former member
snap's Avatar
My System: Sky Plus V3 TDS 470n, Pace 2600CI, Thomson Sky HD, Technomate 1000D, Prodelin 1.8m dish + Invacom Quad C120, CM feed, Lacuna/Wolsey V3 meter
As 80cm is regarded as OK for Barcelona, you should have no problems with 100cm. The comments from Ibiza don't count for you as you are in a hot spot, unlike the Balearics.
Choose from the following LNB's : Invacom, MTI blue line. The new MTI 0.2 white LNB is OK but not as good as the Blue Line single 0.3 (Not the twin).
Avoid the others recommended by previous posts as I have done some tests recently on these and Sharp LNBs with a newly released Satmeter. The Sharp performed poorly in these tests.
(Results should be posted here soon)
snap is offline   Reply With Quote
barcelona, freesat
