LNB comparison tests
Old 07-11-2006   #51
Former member
snap's Avatar
My System: Sky Plus V3 TDS 470n, Pace 2600CI, Thomson Sky HD, Technomate 1000D, Prodelin 1.8m dish + Invacom Quad C120, CM feed, Lacuna/Wolsey V3 meter
It confirms the many reports from around Europe citing the BlueLine LNB as a good performer on Astra 2D. It would be very sad if this model has been discontinued.
snap is offline   Reply With Quote
Old 26-11-2006   #52
Former member
snap's Avatar
Invacom C120 comparison
Hi, Here's another test. The weather has turned really wet and cold, so it's becoming more difficult.
I tried the three C120 Invacom LNB's against one another. The quad is the same as used previously.
It seems to bear out suspicions I've had before I got the meter. There's a quite a marked improvement when changing from the single to a quad, but only on weak 2D signals. The difference is beyond the normal manufacturing range found in these LNB's (note that each one is tested before it leaves Invacom, and has its test printout in the box).
The difference between the twin and quad is closer to call, and needs a greater number of samples. It still seems that the Quad is the one to go for. The particular twin used seems to be better on vertical TP's and also high band TP's.
The results for TP 24 (Channel Four) and TP 31 (FIVE) expose the limitations of the Wolsey meter and ought to be disregarded. The TP 4 (default transponder) seems to be accurate.
I've aslo posted some pix of my installation on one of the few dry days recently. Note the close up of the LNB. The plastic adaptor on the ChannelMaster feed is back to front, as I found there is higher gain to be had by increasing the distance from the dish to LNB. You have to be careful doing this, in case the feed starts to pick up interference from behind the dish. I think the F/D ratio on the Prodelin I'm using is very slightly different to the equivalent ChannelMaster, for which the feed is designed.
LNB comparison tests-3-invacom-jpg   LNB comparison tests-dish_2-jpg   LNB comparison tests-lnb_1-jpg   LNB comparison tests-lnb_2-jpg
The Following 5 Users Say Thank You to snap For This Useful Post:
denby (27-01-2008), enoc (19-05-2008), horizon80 (01-02-2008), jtkeep (27-04-2008), Muad'Dib (01-07-2008)
Old 27-04-2008   #53
My System: dell
Hi snap,it,s realy invacom twin better than quad on vertical transponders on astra2D?Are you tested Inverto IDLP S-FLANGE 0.3 White tech on Astra2D?
piratt is offline   Reply With Quote
Old 28-04-2008   #54
Former member
snap's Avatar
No, I never got round to testing the Inverto.
The result for vertical 2D using a twin is what I read off my meter, it may be correct, but the difference is small.
Since I did this test the quad I used was hit by lightning and destroyed. The one I replaced it with was significantly better on 2D horizontals. Invacom made some kind of modification about a year a go. The one I fitted had a 'Optimised for HD' sticker on the box. No one really knows what this means, apart from Invacom.
Old 28-04-2008   #55
koansrc's Avatar
My System: CM 3.0m @ 28.2 w PACE
The one I fitted (invacom) had a 'Optimised for HD' sticker on the box.
So does the one i recently bought. But I am yet to be convinced for the triple price tag for an invacom having now tried a twin and a quad and comparing them with cheap mti and maximum.
koansrc is offline   Reply With Quote
Old 28-04-2008   #56
My System: cm120
mti blueline? mti have so many different lnb's, supreme that are blue etc
whatr is the apxxxx number on a real blueline
and snap, thanks for all the efforts you make
12man is offline   Reply With Quote
Old 29-04-2008   #57
Former member
snap's Avatar
Sadly the MTI Blueline seems to be discontinued. The last one I bought was on E-Bay, old stock I think.
The last MTI I tested, the AP8-T2NRC, was really mediocre. (has a rain cover which slides down to protect F connector)
The MTI C120 versions are particularly bad, I have a AP82-TW which has never been used in an installation, the performance is so poor.
Old 04-05-2008   #58
My System: 1.8m ChannelMaster +Invacom C120 Quad - Astra 2, plus 80cm Hotbird. Deltasat & Aston Wamba receivers.
Invacon 2D Horizontal Improvement
Hi Snap,
The improvement in the Invacom C120 sounds very interesting. Do you (or does anyone) see significantly better 2D horizontal performance from recent LNBs?
Can you give any indication of what that means for BBC 3/4 (say!!) evening/nighttime reception in the Madrid (say!) area?
Finally, is there an easy way to tell, by looking at it, if my current C120 is pre or post this improvement? I chucked the box away just weeks ago I think...
Many thanks for any info you can provide,
R.
rcarr is offline   Reply With Quote
Old 04-05-2008   #59
Former member
snap's Avatar
I now live in the UK and only visit Madrid every couple of months. Last time I was there we were getting BBC 2/3/4 for 24 hours/day without any breaks. I'm there again this coming weekend and will see if things have changed. I'll try to make a note of the serial number of my LNB which you can compare with yours to see if it is later.
BBC2 was much better after the LNB change, so this also means BBC 3 and 4 on 10773 H. What you report has nothing to do with Freesat, more likely the change in temperatures.
Try to keep your LNB cool if possible.
Old 08-05-2008   #60
My System: dell
I tested today again my invacoms single and quad on prime focus dish 1.80 on weaker transponders on astra2d/i have only vertical transponders/single invacom works 1-2% better on 10.729V other vertical transponders is the same Signal Quality on Astra1 19E on 12.441V invacom single give me 70% signal quality but invacom quad QDF-031 only 58% this frequency 12.441V on astra2 28 E signal quality the same single-91-94% quad-91%SQ why is differnt on astra1 19E in signal quality results from invacom single SNF-031 and quad QDF-031 may be better cross polarization on invacom quad show realy signal quality level without interference and SQ is small?
Old 11-05-2008   #61
Former member
snap's Avatar
The real benefit from the Invacom quad comes on low band frequencies, not high. Can only explain the strange result on Astra 1 from some kind of combination of interference and skew settings. Skew is highly critical in cases of cross- polar interference, a fraction of a mm can make SQ jump from zero to way up the scale.
You also have to use relatively new LNBs to test together as they all deteriorate with age.
Old 12-05-2008   #62
koansrc's Avatar
A fraction of a mm ?
That is figure of speech isn't it ?
Old 12-05-2008   #63
iceman's Avatar
My System: 3.0m Motorised Channel Master 4 fixed dish SKY_HD DM7020s Vsat Kathrein UFS-910 HD
you could take it as figure of speech but i agree with snap,skew adjustment on 2D is so sensitive you could have and loose the highest level within milimeters...That's the reason a good quality (professional) digital strenght meter is required for best results..
iceman is offline   Reply With Quote
Old 12-05-2008   #64
Former member
snap's Avatar
It really is that critical on the most sensitive TPs where you have an issue of cross-polar interference, maybe not millimeters but fraction of a degree twist.
Re: post #59 above, the serial numbers of the new version 'HD optimised' Invacom Quad LNB QDF-031 will be higher than the following:
5070710 BC 0010990
Old 12-05-2008   #65
My System: dell
On my Invacom quad QDF-031 i receive this year serial number is 4041111BC0001200
Old 13-05-2008   #66
My System: None
Don't put serial numbers out on a public forum
Prodelin is offline   Reply With Quote
Old 16-05-2008   #67
Former member
snap's Avatar
Why not? Can't see what anyone is going to do with an Invacom LNB serial number.
Piratt, your LNB is appears older than the one mentioned above bought one year ago in May. Your serial number is lower, but you could check with Invacom to make sure serial numbers are incremental.
Old 30-06-2008   #68
My System: DB7000S HDD USB2GB; 2CM120+Norsat4106Afor HH&7707AforVH on 7°W; Triax 2X110, 1X88 and 1X64. LNBFs: 2BESTQ, 2InvacomQ; 3XAlps, 2Inverto(1Q), 3XBEST; Switches and M/S; Centauri P-168. 30w, 8w, 5w , 1w, 5e, 9e, 16e, 23e, 28e; 13E, 19E; 26E
hi,
When you use a corrugated CM Feedhorn with a C120 LNB which has a round input.
Which Channelmaster version feedhorn do you use?
The round throat 611-6060-17 or the WR75 throat 611-6060-07.
canofan is offline   Reply With Quote
Old 02-07-2008   #69
Former member
snap's Avatar
You need the circular Channelmaster feedhorn for mixed polarity signals, I believe it is WC75 interface.
WR75 is for single polarity LNBs.
The Following User Says Thank You to snap For This Useful Post:
canofan (03-07-2008)
Old 03-07-2008   #70
I am using a 611-6060-10 feed assembly for the 11.7 to 12.2 ghz band with a Norsat 7706A and it is miracles above what I was using before.
However the feedhorn (CM3040645) has a WC75 throat and I had to use the included WC75 to WR75 transition to make it work OK.
I cannot help thinking that, if I had a WR75 feedhorn (CM3040605), I could remove the transition, and its insertion loss, to achieve even better performance.
I estimate the transition to introduce 8° to 15°K to system noise. Am I correct?
The difficult thing is that, when you order the longer single polarity feedhorn, you are not sure what you receive: will it be the WC75 plus transition or the WR75 version?
Sales Engineers accept orders by Feed assembly numbers and not by feedhorn numbers.
I also need a WC75 corrugated CM feedhorn to use with C120 universal LNBs and I do not want to receive the WR75 instead.
Could you help?
Old 04-07-2008   #71
Former member
snap's Avatar
ASC signal (formerly ChannelMaster) feed assembly part no 611 606 007 is the circular throat feedhorn, junction block and other fittings for use on standard C120 LNBs such as Invacom. This is what you normally receive if you ask for a ChannelMaster feedhorn.
I may have a WR 75 feedhorn in my parts box in Madrid, which you are welcome to have. I'll have a look on my next visit.
The WR 75 feeds came as standard with Prodelin dishes in Spain, and are useless for standard LNBs.
Your estimate for insertion loss for a transition (converter WC75 circular to WR 75 rectangular) I'm not sure about- but there is a significant loss if you use one of these, so they are best avoided if the signal is very weak.
Old 07-07-2008   #72
Thanks for your generosity snap but I would like to pay for it and all expenses involved. I would be pleased to have, at last, the 611-6060-10 that would work without the transition on WR75 LNBs. Please let me know and I shall PM you for my details.
Old 08-07-2008   #73
My System: skybox plus an M Vision satellite receiver for astra 1 and Hotbird
Thanks for the last comments Spiney. I'd thought of the feedhorn variable, so in this new test I tried an Invacom with the oher commonly available offset feedhorn made by Gibertini. It is designed for an F/D ratio of 0.66. ChannelMaster and Prodelin do not publish the ratio of their dishes (I ought to go out and measure my dish, but it's raining hard)
I found that a ChannelMaster feed worked better on both the 1.2 and 1.5 Gibertini antennas.
The results confirm many anecdotal comments in forums over the past few years. The most commonly recommended LNBs have been MTI BlueLine and Invacom, and these tests confirm this. I only had one BlueLine to try, and I had to use it in an installation before the night-time testing, which was a pity. I had four MTI white 0.2 examples, they were all very similar, much worse than the BlueLine single 0.6 (so much for manufacturer's noise figures!).
The MTI BlueLine single was better than the twin. The MTI twin's rear port was better than the front.
What was really surprising was the poor performance of the Sharp 0.3. It was so bad I thought I had used a duff unit, so I went through the others on my box. (I've been removing these from customers' dishes for the past year, replacing them with Invacoms) See second attached image for another test on six Sharp 0.3 LNBs.
No Sharp LNB could produce a lock on 10773 H BBC transponder at 10-30pm. They varied quite a bit on vertical TP's, as you can see. They perform OK in the daytime but fail dismally to hold a signal when it weakens in the evenings (when most people want to watch TV)
It is hard to replicate a very weak signal by covering up part of a dish. I tried this and my meter went crazy. In this part of Spain, horizontal TPs are VERY weak late evening.
It's worth saying that Sharp is very popular in Spain amangst expat installers, no doubt because the trade price is so low (about £10), whereas Invacom and MTI are the most expensive. Draw your own conclusions. For me, installing one of these on a ChannelMaster is like putting a Reliant Robin gearbox in a Porsche.
I chose 5 transponders, a mix of hi and lo, V and H. I think the problem with 12304 H, FIVE, is that there is interference from adjacent transponders, not that it is particularly weak.
On my dish with the reference Invacom I get all channels all day in wintertime. In summer BBC2 can start to go about 11pm. Recently, since 10th October, sun outage day here, the 2D signal has been markedly stronger.
I intend to run this test again when I have bought some more MTI BlueLine, to get a night-time result.
In this test I have drawn a threshold line to represent a clear picture. I had a Pace 2600CI (since sold) alongside a Pace Sky+(TDS470n- same tuner as 430n) on the same LNB to try to get an idea of the level of signal each needed. You'll probably be aware already that the 2600CI has a lower threshold. On the scale my meter produces, the 2600 needs 33/4 or value of 85 to be clear, the 470n needs 41/4 or value of 86.
Calibration was set to 030 on the Wolsey meter.
For some reason I don't understand, the breakup threshold is lower on high band. Is this due to the frequency or the different data rate and error correction?
Although this message is old I am assuming this thread is still alive, since I received a link through my e-mail just yesterday, so here goes my question: I live in Madrid and I managed to get an official subscription to sky which I pay regularly and I indeed had a channel master dish with a sharp lnb installed by an expatriate installer; I must say that I have read often about good lnbs for fringe reception but never decided to take the jump and install for example an invacom mostly for fear of not being able to install it myself and not knowing a reliable installer to do it. If the difference is so appreciable, specially with the BBC, I think I would go for it so, is it really worth it? any help locating a reliable installer on the norhwestern suburbs of Madrid?
Thanks in advance for any help.
artafernes is offline   Reply With Quote
Old 08-07-2008   #74
My System: None
I would say save your money and get a Inverto Quad C120 LNB.
My friend bought one recently and got better performance than twice as expensive Invacom Quad.
I have ordered one myself and will be please to post the results when i get it.
Old 09-07-2008   #75
iceman's Avatar
Interesting LNB performance study..
http://www.ofcom.org.uk/research/tec.../2007-0106.pdf
The Following 2 Users Say Thank You to iceman For This Useful Post:
BGonaSTICK (05-08-2008), joekir (20-07-2008)
comparison, lnb, tests
