Originally Posted by thegadgitman OK THAT DID IT. Got an Invacom and feed and that sorted the problem. What a PIG of a dish to fine tune ! ! ! ! |
How I wish I had internet access at my place in Spain. I was out there at exactly
the same time, with the same dish you have (Fortec 2.4m). I took my Pace digibox
with me and spent many days over my 5 week stay trying desperately to get any
kind of reception.
The annoying thing was I also had a SS2 card in my PC. Using that I could see
signals from
Sky One coming in peaking at about 11dB SNR, so I knew I was pointed at
the right place ..... but for the life of me I couldn't get a squeak out of BBC/ITV on it or
anything at all from the digibox - just continuous "no satellite signal" messages.
I was beginning to think, like you, that there was some sort of problem with my LNB
even though I had swapped the one that came with my Fortec dish for a known good 'un
I brought as a spare.
I'll also try the fishing line idea to check that the dish is square/focussed. I did notice
that tightening up the bolts holding the dish onto the mount gave me an extra 2dB SNR.
So here's the stupid question section of the posting.
Given that I should toss the generic LNB and get an Invacom C120 and a feedhorn,
are there any other things I should know before I go back out there in January?
(this is one of those "I don't know what I don't know" kind of situations)
any suggestions are gratefully received
Pete
