Originally Posted by Janus_ru Dear Nick
IMHO wires are a waste of time.. you need adjustability in your bracing.
Install the dish, making sure you get the best signal from 2D, by trying to point directly at it.. ( try to use the diagonal (polar adjustment) only when you are near maximum.
THEN fit adjustable bracing ..
see attached photo
..if you zoom in you'll note bottle screws.. amazingly, adjusting these often sends the signal up more.... no more call outs after winds .. |
The wires are a matter of opinion, I personally think they are superior to fitting a bar, however I have never seen one like the one you have in the photo. The fact is that I didn't like the Bar arrangement because there was no adjustability in that type of brace, but again, yours seems different. The wires that I fit do have adjustability...I fit turn buckles to them and tighten them whilst watching my spectrum and or TV picture. Like you, I have also noticed improvements in signal as I adjusted one of the wires but always assumed it was a further fine tune of the dish. I never thought it was improving the overall gain of it. I will have a closer look at this. My own Famaval is virtually new and has no bracing fitted at present. Over the next few days I will fine tune it to get the gain as good as possible in the evening without bracing fitted, then I will fit the wires and adjust to see what happens.
I can't make out the detail on the dish to see the adjusters. Any chance of a higher res piccy? If you can't post it to the thread then can I PM you my Email so you can send it that way?
Thanks for all the input Janus.
Cheers
Nick
