Can one dish feed two Digiboxes?
Old 01-03-2007   #1
My System: Sky Digibox - Pace 2600 C1 Sky HD box - Thomson 1.8m Channel Master QDF-031 Quad LNB 0.3dB C120 CM Feedhorn
Hi!
Is it possible for two Digi boxes (Pace 2600 C1 x2) to share the feed from one dish or will this have an adverse affect on the signal quality? The idea is to have one receiver in the lounge and the other downstairs in my cinema room.
Any ideas?
Cheers,
Martin
stammerman is offline   Reply With Quote
Old 01-03-2007   #2
Sky Remote Breaker...
2cvbloke's Avatar
My System: Mostly gathering dust cos there's no room for dishes here... :(
The Sleepy Hollow pollracle has spoken!
I notice you have a Quad LNB, if you have a spare output(s) on the LNB, just connect the extra box(es) and you should be ok...
As for sharing one cable, it can be done, but is not reccomended and can damage your recievers if not set up properly, and you'll ony be able to watch channels on the same band as the other box, so there;s little point...
I think your car looks funny too......
Proud owner of a satellites.co.uk cap & T-Shirt...
(though the latter no longer fits due to my ever expanding waistline!!!)
Resident KIRBY Vacuum nut...
2cvbloke is offline   Reply With Quote
Old 02-03-2007   #3
Thanks for the advice - I'll get that done........Cheers.........Martin
digiboxes, dish, feed
