17-03-2007
#3 |
| Specialist Contributor
My System: 3.1m Famaval on 28.2, 1.5m offset on 19.2e, 13e & 7e all mixed in a spaghetti of wires and going into a dream thingy. |
Originally Posted by fibroptik thanks, now i leave it on 501 sky news to test if update from 3.4.4b | That will be fine, no need for 501, but some people reckon it makes a difference. BTW Forced update is also working so try that aswell. Below a recommended procedure for a Forced Software Download (I'm sure other poeple do it other ways - eg some say disconnect the mains for a minute then jump to item 6): (1) Put box into Standby.
(2) Remove the viewing card (optional .. some say it helps)
(3) Press and hold the Back-up button on the Digibox, not the remote control.
(4) Whilst holding the Back-up Button, switch off the power to the box at the mains - either with the switch on the socket or by removing the plug. (5) Count to ten slowly. (6) Keep pressing that Back-up button and put the power back on to the box; (7) When all four lights appear on the Digibox, release the Back-up button If your Digibox is connected by SCART, there will be a message on the screen stating an update is taking place and that it can take 10 minutes. However, it can take longer.
(8) When the box goes back to a single red light, leave it at least a full minute before taking it out of Standby using the Sky button on your remote control.
(9) The box will switch to channel 998 - the Sky demo channel (it may say Searching for Listings - if so just wait until it finishes).
(10) When that clears, do a Services, 4, 5 to check to see the Operating System Version and/or EPG Software Version numbers have updated (the Model Number may also have changed) Step 4 is necessary because if you power off first and then press "Back-up", it does not clear all the old software so follow the above exactly for the most reliable results. A word of warning - if things go wrong with a Forced Software Download, you could potentially ruin your digibox. I take no responsibility for any damage you might cause to your receiver.... DO NOT TRY A FSD IF YOU DON'T HAVE A GOOD SATELLITE SIGNAL. Cheers Nick |
