Cable splitSky+ HD TV General and technical support forum regarding the BskyB HDTV (High Definition) system, hardware, software , installation and channel information. | |
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | DONT try to split the cable - it will never work properly due to switching considerations. Swap the lnb for a quad output and run a new run of cable | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | That is the norm but.... you could also fit a stacker / De-stacker using only a single cable, also mentioned on other threads | ||
| | #4 | |||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
| I think that replacing the LNB or adding just another single one and run a cable will be a lot cheaper, unless running another cable is out of the question because of decoration reasons. | |||
| | #5 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Those are unreliable - I know Satcure stopped selling them as they had so many returned. | ||
| | #6 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Yes, it's last resort if you are unable to run a second cable. They are cheaper than that though even retail ![]() They need to be fitted with the correct cable ( benchmarked ) | ||
| | #8 | ||
| From your first post we got the impression that it is YOUR dish. As it is a communal, it could complicates things as you need the consent of all the neighbours to make changes, as it would cost money and perhaps not all of them want to pay for the cost of these changes. Suggest to talk with your neighbours and see what they think. | ||
| | #9 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | If it is communal, you need to identify whether there is a redundant output on the multiswitch, then your only option will probably be a stacker de-stacker, unless of course a secondary cable run is possible. PS. Beware making changes to communal systems unless you a) have permission and b) have the knowledge to do it (if not, use the company who installed it), as losing another resident his TV signal can cause a lot of upset, losing it for the whole block can cause riots. | ||
| | #10 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | LOL ![]() | ||
| cable, split |
