Freesat card for Channel 4 HD
Sky+ HD TV General and technical support forum regarding the BskyB HDTV (High Definition) system, hardware, software , installation and channel information.
Old 13-10-2008   #1
My System: 70cm dish motorised, Arion af8000hdci receiver, Diablo v2.3, cas 3+, ***** super dark motor, 60cm fixed 19e anologue.
Originally Posted by Llew View Post
It's free to view only with a Sky card (or a Sky Freesat card for a one-off 20 quid purchase).
where can i get one,i have no sky equipment so will they let me have one
physcogem is offline   Reply With Quote
Old 13-10-2008   #2
rolfw's Avatar
Real name: Rolf
You can order a Freesat card from Sky, but you will need a Sky digibox to activate the card, nothing to stop you buying a cheap one on Ebay.
Rolf
Old 13-10-2008   #3
ok can get box from freind. will the card open 4 hd thats all im interested in.
Old 13-10-2008   #4
Robbo's Avatar
Real name: Mark
Yes, it will, I have one running in my TM6800HD.
Old 13-10-2008   #5
without paying the 10£ a month hd option?
Old 13-10-2008   #6
Robbo's Avatar
Real name: Mark
Yes, it is not necessary as CH4 HD is a Free to view channel, not sure if it is needed on a Sky HD box though.
The Following User Says Thank You to Robbo For This Useful Post:
physcogem (13-10-2008)
Old 14-10-2008   #7
hope this makes sense. I have a box and a card that had films on etc but was cancelled abt 1 year ago question is will this card still show the stuff i want ie freesat from sly. appreciate that if it does still work it will need leaving in the box for afew days to update. if it does work it will save me the 20£ for a new card
Old 14-10-2008   #8
Robbo's Avatar
Real name: Mark
It depends what you mean by 'cancelled'.
I had a Sky subscription that finished approx 2 years ago, with the 6 mix plus movies. I phoned up Sky and cancelled all my subscriptions, and YES the card still works alright as FTV. So, so should yours. As you say, the card may have fallen asleep, so it may take a little while to wake it up. LOL
The only problem you are going to have is that you have no Sky equipment, as the card will need popping back into a Sky box once in a while, as the Diablo can't do it.
I don't know what the period is though, I'm sure I have had mine in my TM for over a month now, and it is still going strong.
physcogem (14-10-2008)
Old 14-10-2008   #9
thats sounds good, father in law cancelled subs to sky and still has box so should be able to loop through arion and wake up the card.
i only want 4 hd be a lot easier when it goes fta
Old 14-10-2008   #10
Robbo's Avatar
Real name: Mark
Yes, that will work, if you pick the correct transponder range and satellite on the Arion, alternatively, send to 28E and turn the Arion OFF. Better still, get a twin LNB.
Old 14-10-2008   #11
got dish on 28e what is best channel if any on sky box to leave it to wake up?
i have got twin lnb and if this all works ok will run another sat cable to enable box to be left connected all the time
Old 14-10-2008   #12
Robbo's Avatar
Real name: Mark
Not sure, one of the installers on here who does Sky will know. One of the reasons why I suggested leaving the Arion in the OFF state, was so that the Sky box could do its thing (whatever that is) with access to whatever it needed.
Old 14-10-2008   #13
got the arion off, sky box says no sat signal if arion on, sky box is working on fta fine so card should work when fully updated gonna leave it on overnight
Old 14-10-2008   #14
Robbo's Avatar
Real name: Mark
By the way I have had my Sky card in my box for 6 weeks now, I just checked, not sure if the box updates the card or it hasn't needed one yet.
Old 15-10-2008   #15
in sky box, card will open ch 5, put in diablo cam nothing happens, do you know if it opens 5 on sky box then card is updated fully. i would of thought this be the case
i dont know if cam settings are right till the card is updated, chicken or the egg i suppose
Old 15-10-2008   #16
Robbo's Avatar
Real name: Mark
I think it can do bits at a time, so if you can see ch5, it just means ch5 is done, there is also Sky 3 and a few others. I only use it for ch5 and ch4 HD.
Old 15-10-2008   #17
i had the card the wrong way up, what a donkey, got 5 and 4hd so at least i know cam is set up right . will just keep topping it up .
at least sly did not get the 20£ from me .
thanks for your help
Old 15-10-2008   #18
Robbo's Avatar
Real name: Mark
LOL, Yep, I think I did the same thing with my DigitAlb card in my Conax Cam.
Glad you got it sorted.
Old 16-10-2008   #19
Supporting Advertiser
cdtronix's Avatar
My System: TM6800 HD Super+, TM5400CI, Triax 1.1m Dish & Moteck Motor, also Triax 78cm Dish with Moteck motor. Global Single LNB, Ice Quad LNB.
When actiavting these cards for customers I always leave in sky box on ch4 over night & by the morning 99% of the time, the card is back on again.
www.cdtronix.com Tel:+44 (0)1206 825155
Sky, Freesat, Dishes, 0.1db LNB's, XXX Viewing Cards, Cams, Quality Coax Cables
cdtronix is offline   Reply With Quote
The Following User Says Thank You to cdtronix For This Useful Post:
physcogem (16-10-2008)
Old 14-11-2008   #20
My System: AB IPbox 9000HD, only a fixed dish for now..
I recently got a s*y box that had not been used for 3 years!, a Panasonic TUDS840. An expired contract card was left in it. I just left it on standby overnight, and the card came to life, ch5, 5US, sky3 etc all now available. It doesnt matter if you leave it on or not, just leave the mains plugged in. I then did a forced update, now it works a treat.
Now I want to find out what software I need to use the s*y card in my AB IP box 9000HD. Anyone any idea? It has 2 card slots, and a slot for a CAM.
bobdisk is offline   Reply With Quote
Old 14-11-2008   #21
Robbo's Avatar
Real name: Mark
Not all receivers are capable, or don't have the software support to do it.
It is not on my list of receivers that do work with a Sky card.
What you do, is find the support forum for your receiver, and download the latest patch for it, or whatever method is used to update it. If it doesn't work, then it won't. You would have to stick a Diablo in it instead.
card, channel, freesat
