Transfer recorded data from Sky HD box to PC?Sky+ HD TV General and technical support forum regarding the BskyB HDTV (High Definition) system, hardware, software , installation and channel information. | |
| Regular Member Join Date: 03-02-2009 Location: Greece
My System: Gibertini OP120 + Inverto Black Premium Twin @ 28.2E |
I am interested to know whether is possible to transfer from the Sky HD box any recorded data to a pc or a hard drive. Thank you. | ||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | This should get you going in the right direction http://www.satellites.co.uk/satellit...-only-fta.html | ||
| The Following User Says Thank You to PaulR For This Useful Post: | w4tt4n4b3 (04-02-2009) |
My System: Gibertini OP120 + Inverto Black Premium Twin @ 28.2E | Thank you, Paul R. I was thinking of another alternative way. Buy a hdd dvd recorder and record the data. But will the recordings be at hd quality? If I record HD programmes. Can a hdd recorder be connected to a Sky hd box? | ||
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | I don't have HD so can't be definitive hiwever I suspect not. In an ideal world if the $ly+ box has component output and your DVD recorder can accept component then yes but you may find that dome of the programmes you want to record are diasabled by $ly on the component output, i.e. they're only available on the HDMI output. | ||
| | #5 | ||
| HDMI connections are *almost* always one way, ie, what is an output is rarely an input. I suspect the recorder you are thinking of using will not have an HDMI input. | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| | #6 | ||
My System: Gibertini OP120 + Inverto Black Premium Twin @ 28.2E | Thank you. One solution would be a hdd dvd recorder. Can one be connected to sky hd box? In the sky hd box page says that: If you're running out of space on your Sky+HD box's hard disk, you can copy recorded programmes you want to save onto video tape or DVD. While you're making copies you can watch the programme being copied but you can't watch another programme. HD programmes are copied in standard definition quality. If I get the ordinary Sky box without hd will I be able to connect it to the pc to record some programmes? | ||
| | #7 | ||
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | I suspect that they mean that the receiver and recording device are connected by a scart lead, which by definition is an SD link. As far as I can see, the only way to make an HD recording (theoretically) is to use the component output on early HD boxes (later boes don't have them I believe) and somehow or other make the reording from that. | ||
| | #8 | ||
My System: Gibertini OP120 + Inverto Black Premium Twin @ 28.2E | You must be right, they must be thinking that the only way to restrict users to copy in SD is to give them only SD outputs available... When you say early HD boxes? could you give me hint? I mean either name or something else that would help me identify them. | ||
| | #9 | ||
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | Unfortunately I'm only going on what I've read so can't be much help. I think that all $ly HD boxes are made by Thomson so that's no help. Component outputs are phono sockets and there will be 3 of them labelled Y, Pb and Pr. You will also need to arrange for an audio connection to te recorder. All this assumes that there is a recorder which will accept HD and component of course! | ||
| | #10 | ||
My System: Gibertini OP120 + Inverto Black Premium Twin @ 28.2E | Try to google the work hauppauge hd pvr and I think you will find a device. I would give you a link but they will send me another warning for posting external link I guess... | ||
| | #11 | |||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | _http://www.bbc.co.uk or paste it in and change some of the letters in the start of the address: hxxp://www.bbc.co.uk | |||
| | #12 | ||
My System: Gibertini OP120 + Inverto Black Premium Twin @ 28.2E | I got the impression that the problem was not only the direct link but even the reference to another site as well... Ok then. If I do it like this is there a problem? _http://www.hauppauge.co.uk/site/products/data_hdpvr.html | ||
| | #13 | |||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
| Please edit your post by deleting the Code and just add underscore as Analoguesat suggested. | |||
| | #14 | ||
My System: Gibertini OP120 + Inverto Black Premium Twin @ 28.2E | Dear PaulR, if instead of trying to extract hd recorded data from the pvr box I try to record HD straight to my pc during the broadcast time using a card like this _http://www.blackmagic-design.com/uk/products/intensity/techspecs/ will I have any success? Can the hdmi port be blocked or the transmitted hd data be under copyright protection system that the pci card won't be able to record anything? | ||
| | #15 | ||
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | You've obviously done a lot of Googling to find all these products! The Hauppage PVR is interesting as it seems to be exactly the device I talked about as it an accept component signals. So it should work, I reckon. The PCI card is also interesting as it is one of the few devices with an HDMI input. The biggest problem, as I see it, will be the HDCP copyright protection that can be applied by the $ly HD box. If the $ly HD box doesn't receive the correct handshake back then it will stop (or not even start!) sending a signal down the HDMI cable. AFAIK this HDCP hasn't been broken and you will have to rely on the fact that a lot of programmes aren't copyright protected. But I would guess that most of what you want to record will be! | ||
| | #16 | ||
My System: Gibertini OP120 + Inverto Black Premium Twin @ 28.2E | Dear PaulR, Ι can't get it as far as the pci card is concerned. My tv has an hdmi input. If I connect the Sky Hd box to the hdmi input, it will work right? Now how can Sky can recognise that I connect the box with a pci-card and not my tv since both (TV and pci card) have the same input. I am not very experienced on this field that's why my questions may look naive. | ||
| | #17 | ||
| Quote from the spec: The HDMI standard sometimes includes copy protection encryption, such as commonly found on DVD players and some brands of set top boxes. When connected to these copy protected sources, the HDMI specification defines that Intensity cards cannot capture. Always confirm copyright ownership before capture or distribution of content. Intensity media file formats are fully compatible with DeckLink and Multibridge capture cards. Compatible with Microsoft Windows™ and Apple Intel based Mac Pro systems. Apple Power PC systems are not yet supported. The manufacturer wouldn't have a HDMI license without complying with the HDMI standard. | ||
| | #18 | ||
My System: Gibertini OP120 + Inverto Black Premium Twin @ 28.2E | So if the tv material is copy-protected the capture card reads that there is protection and it won't capture... The same applies for a device like hauppauge? How can I learn which broadcasts are copy-protected? Interested mainly for Sky Sports channel. | ||
| | #19 | |||
The component outputs are analogue NOT digital signals. There is always the chance that the HDMI copy protection might prevent it from capturing the video, even on component. Why not buy both and report back? | |||
| | #20 | ||
My System: Gibertini OP120 + Inverto Black Premium Twin @ 28.2E | I was not talking about the hauppauge mainly but about the Blackmagic Intensity pro... But read the following from the sky page (_http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=69037876-a1d0-48a9-9f03-354f177d80ab&articleId=2334910) Copying programmes to video or DVD If you're running out of space on your Sky+HD box's hard disk, you can copy recorded programmes you want to save onto video tape or DVD. While you're making copies you can watch the programme being copied but you can't watch another programme. HD programmes are copied in standard definition quality. So according to that, HD programmes can be copied.But I think I need a few clarifications Case no1: You are running out of space in the SKY Hd box. You can transfer through scart some of the contents of your sky HD box into a videotape or dvd. You can record live/capture only with the SKY HD box. While you copy content from Sky hd box to video or dvd-r you cannot watch any other programme. Case no2: You are running out of space in the Sky HD box. You can connect a video or a dvd-r through scart with the SKY hd box and record live any programmes you want. So you don't mind PVR hard disk is full. While recording a programme live you can not watch any other programme/channel. HD programmes are copied in standard definition quality. Do they mean that when you record them with the PVR are recorded in SD quality? Do they mean that in the pvr they are recorded as HD but when you want to copy them to dvd or video you have to connect via Scart so the result of copy will be SD. Do they talk about SD because they did not have in mind that there will be devices with HDMI input? | ||
| | #21 | |||||||
The long and the short of it is that $ly don't want you to make independant recordings of valuable programmes in HD that they, and others, could possibly make more money out you by selling the programme to you again. | |||||||
| box, data, recorded, sky, transfer |
