Connect Sky HD with PC via HDMISky+ HD TV General and technical support forum regarding the BskyB HDTV (High Definition) system, hardware, software , installation and channel information. | |
| Regular Member Join Date: 03-02-2009 Location: Greece
My System: Gibertini OP120 + Inverto Black Premium Twin @ 28.2E |
Mates, I would like to ask if I connect the Sky HD box with my PC via the HDMI and specifically connect the HDMI output of the box with the HDMI of my pc's graphics card will I be able to have the HD signal on my pc's screen? | ||
| | #2 | |||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
Is the HDMI connector defined as input or output? Does it have both? | |||
My System: Gibertini OP120 + Inverto Black Premium Twin @ 28.2E | The pci capture device has both hdmi input and output. I will give you a link. _http://www.blackmagic-design.com/uk/products/intensity/techspecs/ Could this work? If I get a cable from the hdmi output of the Sky box hd and connect it to the hdmi input of this pci capture card will I be able to capture hd with/to my pc? | ||
| Nice looking card. As it has HDMI input, then I suppose that it will do the capturing in HD. Will not work if your source is copyright like a commercial DVD. Please report back. | ||
| | #5 | |||
My System: Gibertini OP120 + Inverto Black Premium Twin @ 28.2E | So is there a chance the hdmi port of the sky box will be blocked in case it gets connected to/with a card like this? | |||
| | #6 | ||
| | #7 | ||
My System: Gibertini OP120 + Inverto Black Premium Twin @ 28.2E | I do not own the card. And there is something else. HD from sky costs 10 pounds each month extra. If this does not work then I will not go for the SKy HD package but for the ordinary one. Sky contracts are binding for one year, as far as I know for new customers. | ||
| | #8 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I think you'll find that much of the Sky HDMI output is copy protected, hence why they disabled the component HD outputs on the box, forces evryone to use the HDMI. I like the standard model, at £160 not a bad price either _http://www.smartdv.co.uk/product.php/181/43/ | ||
| | #9 | |||
If you're running out of space on your Sky+HD box's hard disk, you can copy recorded programmes you want to save onto video tape or DVD. While you're making copies you can watch the programme being copied but you can't watch another programme. HD programmes are copied in standard definition quality. So you can copy the HD programmes in the PVR and when running out of space, connect the (scart probably) to your VCR or DVD-R and copy them. I say scart because they refer to SD quality, so the only way to copy from HD to sd is to use the scart to extract the hd content from the PVR. So you say that if I connect the HDMI output to the HDMI input of the Blackmagic Intensity Pro pci card the card will not capture anything because HD programmes are copyright protected. Right? | |||
| | #10 | |||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 |
Correct. If the $ly HD box is showing a programme which is copy protected then, if it doesn't get the correct "answer" from whatever device it is connected to with the HDMI cable (TV, recorder, whatever), it will not allow a signal out of the HDMI port. | |||
| connect, hdmi, sky |
