sky HD reception problems in athens.
Sky+ HD TV General and technical support forum regarding the BskyB HDTV (High Definition) system, hardware, software , installation and channel information.
Old 24-03-2009   #1
My System: HOTBIRD, PC
hi, i have a sky HD box installed for the last 6 months, replacing my old standard box but it hardly ever works.
i get the "no satelite signal received" on my screen or "there is a technical fault with this channel, try later".
it has worked before though and i had a clear signal for some time.
my old box was working fine but it was loosing one third of the channels so i decided to try my luck with an HD box.
i have asked for help from a professional who fixed it a couple of months ago but now i get the same message on my screen.
i'm using a 1.1 triax dish, could it be that this is too small for greece?
the wire length is approx. 15 metres, could it be it is too long?
i have also tried numerous time to reboot the box using the backup key but it doesn't work...
i know this is quite general, but any comments might help.
many thanks!
ILLY78 is offline   Reply With Quote
Old 24-03-2009   #2
Real name: Georgy
My System: dm500s
dish = at least 140 cm !
borgy is offline   Reply With Quote
athens, problems, reception, sky
