Communal Dish ProblemSky+ HD TV General and technical support forum regarding the BskyB HDTV (High Definition) system, hardware, software , installation and channel information. | |
| Member Join Date: 02-05-2009 Location: Livingston, Scotland
My System: SKY+HD |
Hi, Having problems getting full use of SKY HD with a communal Dish. I live in a new build block of flats, the satellite switch with the outlets is in my loft, i have been up to have a look but all of the ports are taken which i don't understand because in my block there are 6 flats but on the switch there are 12 ports - all used up. So its difficult to find out which cables are actually being used. I already bought a reel of cable thinking there was free ports. I'm just wondering about finding a solution, i'm thinking that installing my own dish just outside a window is the best idea. I know that personal dishes arent allowed here, but it isn't enforceable at all, the factoring company can only request that you remove it. Any advice would be very welcome Cheers | ||
| | #3 | |||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s |
By the sound of it, each flat has two satellite feeds (6 flats, 12 outputs). What exactly are your problems? You also need to check that the system isn't under a maintenance cover which could be invalidated if tampered with. | |||
| | #4 | |||
My System: SKY+HD | The problem is that i need 2 feeds for the HD box, only one is available. I thought that aswell , 6 flats 12 outputs, but i can't seem to find where the cables lead to. I guess i'll just have to have another good look, see if theres any free cables. | |||
| | #5 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Have a word with the management company if it's a new build /system. | ||
| | #6 | ||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | Have you taken your wall plate off yet to see if there's a second unused cable rolled up inside the wall box? | ||
| communal, dish, problem |
