sky + help neededSky+ HD TV General and technical support forum regarding the BskyB HDTV (High Definition) system, hardware, software , installation and channel information. | |
| Regular Member Join Date: 11-12-2003 Location: stockholm
My System: 1.2 metre dish thomson sky h.d box |
Hi all my sky plus is not working just says on screen "system fault" have tried to do a system reset to no avail.I also have forced a softwear upgrade. When i try to do a health check it says on the screen your incident number is 5208 please enter a four digit access code. Does any one know these codes ? Thanks in advance Tony Martin | ||
| Member Real name: jace Join Date: 22-07-2009 Location: hull city england
My System: pace hd 9F3004. fitted with a 65cm triax solid dish. beko 32WLA520HD 32" lcd tv . | the codes you need sky have there genarate the code nothing usefull in there .. system fault is a tempory fault unplug from mains for a hour to cool the box box then hold down the left and right buttons on front off box not on remote . plug in mains and wait for play light the press select and let go off buttons wait for 10 mins then try . | ||
My System: 1.2 metre dish thomson sky h.d box | Thankyou problem solved. have lost everthing in the planner but the most important thing is that everything is working again ! | ||
My System: pace hd 9F3004. fitted with a 65cm triax solid dish. beko 32WLA520HD 32" lcd tv . | glad it works now .. shame you lose your recordings . but saves you £65 call out from sky . | ||
| needed, sky |
