SKY+ HD Box installation
Sky+ HD TV General and technical support forum regarding the BskyB HDTV (High Definition) system, hardware, software , installation and channel information.
Old 17-07-2009   #1
Dream-Believer
newgen2005's Avatar
My System: Dreambox 500s, gemini v3.30 80cm dish 1.0w
I picked up my Pace HD box today, I am waiting for the installer to put me another feed in. I live in a flat so we share a dish, in my loft we have the main box I think it is a 12 way one, and has 4 spare feeds. The dish has a 4 cable LNB, these go into the 12 port box in the loft.
My main question is can I use the SKY box with just 1 feed intill the installer turns up? The guy in the shop said I could but it would mean when I try to record it could make the box freeze and would need to be unplugged. I have just connected 1 feed and it is locked on but it's saying 'no satellite signal' Am I trying something that won't work, did the guy in the shop give me the wrong information?
newgen2005 is offline   Reply With Quote
Old 17-07-2009   #2
Dream-Believer
newgen2005's Avatar
All sorted found the answer, located hidden menu and selected single feed
Old 18-07-2009   #3
My System: Skydigibox, AB IPBox 9000HD, DM8000
Could you please tell me how you do this, I've been into the menus and can't seem to find the right one.
Found it, settings options, highlight picture options, press 0, 1, and select.
meagain123 is offline   Reply With Quote
Old 19-07-2009   #4
Dream-Believer
newgen2005's Avatar
Sorry I should have told you how I did it!
Sorted the second feed out myself in the end, used the existing tv socket on the wall and cable, connected a coax to satellite adapter to the socket on the wall, joined the coax in the loft to a satellite cable and connected it to the feed box and that was it!! £11 in cables and connectors, saved myself some cash in the end
Discovery HD looks very nice indeed.
Old 19-07-2009   #5
Toute Ronde Bon Oeuf
Tivù's Avatar
Real name: Gordon
An enterprising solution!
Tivù is offline   Reply With Quote
Old 22-07-2009   #6
Real name: jace
My System: pace hd 9F3004. fitted with a 65cm triax solid dish. beko 32WLA520HD 32" lcd tv .
Thumbs up
hidden menus on new sky hd egp is services 0.0.1 select now . many bugs is found if using the single feed settings
jasonx1 is offline   Reply With Quote
box, installation, sky
