SKY HD box to record Freesat?Sky+ HD TV General and technical support forum regarding the BskyB HDTV (High Definition) system, hardware, software , installation and channel information. | |
| Member Join Date: 21-07-2009 Location: Essex
My System: Sky+ PC | Hi I'm currently just on a Sky+ box and thinking about (a) upgrading to a Panasonic screen with built-in Freesat, (b) whether it's worth getting Sky HD as well and (c) whether there's a way of recording the Freesat HD signal (in HD). Does anyone know if it's possible to upgrade to a Sky HD box but carry on with the normal Sky (non-HD) subscription (i.e. saving yourself a tenner a month) but still use your Sky HD box to record Freesat? I'm a bit new to all this, so tell me if this is a stupid question... Thanks | ||
| Regular Member Real name: Chris Join Date: 20-07-2009 Location: South Coast, Hampshire
Blog Entries: 1 My System: Currently, Nokia 1800S with satscan, analogue receiver, Nokia 9800S, D box with DVB2000, 90cm solid offset dish, Panasonic tv with inbuilt freesat. Sky + HD (for the wife, mostly!) |
If you are getting a Panasonic Viera tv with built in freesat it is possible for the tv to send the freesat signal via the Viera link (HDMI cable or fully wired scart) to a Panasonic Viera DVD/HDD recorder. The TV can control the recorder as well. I have done it a couple of times with my Panasonic TV/DVD recorder setup. I haven't tried recording an HD freesat channel yet though. | ||
| Member Real name: jace Join Date: 22-07-2009 Location: hull city england
My System: pace hd 9F3004. fitted with a 65cm triax solid dish. beko 32WLA520HD 32" lcd tv . | you need to have a sub card from sky to record the channels .. if you want a cheaper way get the freesat recorder by humax price is £299 but when you do the pros and cons you save the tenner a month . and recored in hd | ||
Blog Entries: 1 My System: Currently, Nokia 1800S with satscan, analogue receiver, Nokia 9800S, D box with DVB2000, 90cm solid offset dish, Panasonic tv with inbuilt freesat. Sky + HD (for the wife, mostly!) | With the Panasonic viera link up to a Panasonic HDD recorder you can also pause live tv and time delay it according to the instructions, but I haven't tried doing that yet either! (I have only had the big Panasonic plasma for just over a month and if I could just get the wife away from it for a little while so I could have a play with it................!) A Panasonic Viera HDD/DVD recorder costs around £299, but if you are buying a big plasma with freesat you might get a good deal. At the moment Panasonic are giving a free 5 year warranty, which is worth having as it is from Panasonic themselves not an insurance type extended warranty. | ||
| box, freesat, record, sky |
