New Sky viewing card and T-Rex 4.6
Sky+ HD TV General and technical support forum regarding the BskyB HDTV (High Definition) system, hardware, software , installation and channel information.
Old 14-08-2009   #1
My System: Humax iCord HD SKY+HD HP Pavilion dv9000
Hi
unfortunately I have received my replacement Sky viewing card ( The white one )
does anyone know if its work with my T-rex 4.6 cam like the bule card or not ?
if not does anyone know if there is cam to use or new firmware update for T-Rex cam to fix the issue ?
Tnx..
Masoud_h is offline   Reply With Quote
Old 14-08-2009   #2
It is unlikely that there will be any new software for the Dragon/T-Rex Cams, and so far no new software for other cams to support the new Sky card.
There might be some future updates for the Diablo Cam, or even a new cam released, but at the moment I have only read of some Linux receivers working with the card.
Check out some of the threads in the Dreambox, and other Linux receivers, sections.
Mickha is offline   Reply With Quote
The Following User Says Thank You to Mickha For This Useful Post:
Masoud_h (14-08-2009)
Old 14-08-2009   #3
oh that is bad
but thanks mate for the information!!!
Old 23-08-2009   #4
My System: FireDTV, DVBViewer, etc.
Is there any hard CAM that will work with the new Sky card ? I have a FireDTV and Dragon cam but got sent the new card which wont work. I don't mind buying a new CAM if that is what it takes.
DigitalDelboy is offline   Reply With Quote
Old 24-08-2009   #5
Turok's Avatar
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband!
sky germany cards works good on giga twin cam blue,uk card not tested yet,but it should be the same,works also on oasis cam,but picture,freeze every 3 secounds!
Turok is offline   Reply With Quote
Old 24-08-2009   #6
I haven't heard of any that are working with the new Sky UK card, only linux based receivers at the moment, but support for Cams seems to have stopped. Even the Diablo 2.3 hasn't had any new updates for a while.
There might be some new files being developed, or a new Cam might be out soon, all we can do is be patient.
Old 25-08-2009   #7
Any idea why support seems to have stopped for CAMs ? There are quite a few out there, seems odd that nearly all have stopped.
Old 25-08-2009   #8
Most cards, and cams, have limited support, otherwise we would never have to buy anything new
There is a new Predator file for the Dragon Cam, predator 370, but I doubt that it will work with the new sky card.
No doubt there will be a new cam, released at some point, that will open channels and could work with the new sky card, we'll just have to wait and see what develops.
Old 03-10-2009   #9
My System: Skybox HD Humax Icord HD
I hope they will find soon, i'm fed up to use the skybox hd and hope to use soon my humax icord like i used to be with the old blue sky card...
sirsimontemplar is offline   Reply With Quote
card, sky, trex, viewing
