tips and tricks for your sky hd and sky+ box
Sky+ HD TV General and technical support forum regarding the BskyB HDTV (High Definition) system, hardware, software , installation and channel information.
Old 24-08-2009   #1
Real name: jace
My System: pace hd 9F3004. fitted with a 65cm triax solid dish. beko 32WLA520HD 32" lcd tv .
Thumbs up tips and tricks for your sky hd and sky+ box
tips and tricks for sky hd and sky + systems
full system reset for sky hd (you will lose all recordings)
press services on remote .then go to settings .then press .0.0.1 then select on remote for new epg
for old epg press services type 4.0.1.select the full system reset
full system reset if cant access the menus (you will lose all recordings)
turn power off at mains . then on front off box hold down . left and right buttons in the dail area .hold and turn power on . the play lights up press select on box not remote .and let go off buttons now wait up to 5 mins
software download for buggy boxes
turn mains off to box . and hold down the backup button on the box .turn power on to box . and wait for all lighs to come on .if all lights come on let go off backup.
and wait for the box to reboot you know when all lights go out .
( please note if you have a lcd or plasma tv or older tv you may get screen burn from the logo off the software update so best turn tv off when doing this )
full system planner rebuild ( for slow epg missing listings ect)
press services on remote then go to settings then press 0.0.1 select on remote
for new epg then planner rebuild ..
for old epg press services then 4.0.1 select on remote then planner rebuild
(you will not lose any recordings or listings)
hope this makes a sticky postie
jasonx1 is offline   Reply With Quote
Old 14-10-2009   #2
My System: not listed
known issue with the new viewing cards
you may find that you cannot record onto dvd/vhs , it might say something about a copyright protection, this is a know issue to the new viewcards, to fix this all you do is a download to the digibox (works on all sky digiboxes
turn off the digibox
press and hold back on the digibox itself
turn the digibox back on while holding the backup button untill all lights are on the digibox then let go.
this takes about 10 mins to complete
bobby12345678 is offline   Reply With Quote
Old 4 Weeks Ago   #3
Real name: jace
Thumbs up
what the hell you on about . copyright is for box office films . any sky box can transfer to tape or dvd . and how do you download to a digibox ? and holding the backup button is for software download for when the box is new or you have a bug in the software ..
Old 4 Weeks Ago   #4
recording
i agree with jasonx.
i have never had a problem recording movies from sky tv uk or any other for that matter.
recorded ghost town last night.
there is no copyright protect anywhere on satellite.
if your box is set on the program and tv channel you want to record
and if you are connected with a scart then with the recorder set on av or aux or where evere it shows up it will record.
of you are using a modulated output then the vcr must be set and tunes to that channel.
if the sky box is set on channel 34 the vcr must be locked on channel 34.
other wise no program.
you have it probaly set up wrong somehow
ralph
ralphmagno is offline   Reply With Quote
box, sky, tips, tricks
