Auto-switch resolution in Thomson DSI8215Sky+ HD TV General and technical support forum regarding the BskyB HDTV (High Definition) system, hardware, software , installation and channel information. | |
| Regular Member Join Date: 18-03-2009 Location: SE
My System: None at the moment |
There is a bug in the software in the Thomson DSI8215 which affect the auto-switch option at different resolutions. After a while the box will be stuck in 576i if i switch to a HD channel, only way to sort it is to reboot the box. Anyone know if Sky will fix this bug? | ||
| Member Join Date: 14-10-2009 Location: leeds
My System: not listed | skys fix to this is to go to the picture setting and change this from auto to a hd resolution ie 1080i, the auto part is not actually doing what its ment to, but then again why would you want it on auto if u want to get the best possible picture, best putting the hd resolution to the 1080i and then saving it old menu style services system setup picture setting hd resolution (change this setting anything other than auto) save the new settings new menu style services settings picture hd resolution (change this setting anything other than auto) save then new setting | ||
| autoswitch, dsi8215, resolution, thomson |
