sky italia hd
Discussion on the Sky Italia satellite TV subscription packages.
Old 12-02-2009   #1
Part Timer
don'tknowdon'taskme's Avatar
My System: DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr
sky italia hd
i have just bought a hd sky italia box and card and was wondering if any one on here has a english manual or any way of changing it to english,as i can not seem to get the settings right and the picture is off colour.
If it is not broke fix it till it is
don'tknowdon'taskme is offline   Reply With Quote
Old 12-02-2009   #2
Archived Member
I doubt if you will find one in English.
It will be a good way to start learning Italian.
This thread might be useful
Sky Italia box
HB13DISH is offline   Reply With Quote
Old 12-02-2009   #3
denis1501's Avatar
My System: 1.25m offset dish for Astra2 28deg., 1.2m dual feed for Astra1 and Hotbird, Thomson Sky HD, Humax HDCI2000, Dragon CAM, Invacom 0.3 twin lnb, Dell Dimension 4400 and Inspiron 1525, 1 meg broadband
Press 'menu', then 'configurazione ricevitore' then 'lingua e sottotitoli'.
Change 'lingua audio preferita' to 'Inglese' and press ok to save.
regards
D.
p.s are you connected to your tv via a hdmi cable???
Also go 'menu', configurazione ricevitore' then 'televisore' then 'alta definizione' and set to 1080i. ok to save.
Also go 'menu', configurazione ricevitore' then 'televisore' then 'standard'. Change 'formato immagine' to 16/9 and 'uscita video' to RGB. Press ok to save.
denis1501 is offline   Reply With Quote
Old 12-02-2009   #4
Part Timer
regards
D.
cheers denis1501
italia, sky
