Sky without a telephone connection?Sky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally. | |
| Regular Member Join Date: 26-12-2004 Location: Wirral
My System: 1 metre Channel Master with matched feedhorn + Inverto 0.3dB lnb. 1224 H to H motor ground mounted. Technomate 5400CI+ USB and v-box |
If I buy a Sky box and subscription, can I just plug it in to my current set-up and receive the progs or do I have to have a cable running through the house to my phone line as they state in their blurb ![]() If I have to have a cable, why do they insist on this and what's the reasoning behind it. Is it only for 12 months or not? Thanks Frank | ||
| | #2 | |||
| lifes not a practice run Join Date: 27-09-2006 Location: torfaen south wales
My System: Technomate diseq 1500ci+ and Humax Foxsat HD Acer Aspire 5315 |
i removed mine after 1 month because someone told me that they monitor your viewing preferences and of course you need the telephone line for some interactive devices, take it out m8 and sodemm!!!! deep joy dave | |||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | If you supply your own equipment then you can ring up and ask for a "second hand box" contract. There is no telephone line requirement if you do this. The exception is if you are adding a box for multiroom - in that case there is a phone line requirement for both boxes to be connected to the SAME phone line for the entire life of the multiroom sub. | ||
| Specialist Contributor Join Date: 29-02-2004 Location: Tyne and Wear
My System: 85cm transparent dish 0.2db lnb titanium wf100 cable dreambox500s technomate 9100 linux Eaglebox UK nds card | As soon as the sky engineer left, my telephone connection was pulled out immediatly...4 years on! obviously dont tell sky this | ||
| Nice but Dim | |||
| | #5 | |||
My idea is to get rid of BT Internet as my ISP (as they haven't bothered to upgrade my line to 8 meg since last April despite 2 phone calls!) and replace it with the 2 or 3 picks package from Sky along with the broadband and phone. Quite a good deal at £19 or so compared to the £15 I'm paying to BT just for broadband. I am thinking of taking out the subscription, getting the box and running it through a switch box on my current motorised set-up. I would install it myself as there's basically nothing to it...just connect up the box and cables. Any drawbacks to this masterplan or is it pretty sound? Frank | |||
| | #6 | |||
| | #7 | |||
I think that because I'm an existing customer and not a new one, I'm at the back of the line and they give preference to setting up new ones!! Frank | |||
| | #8 | |||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. |
You are better off to let sky put up a separate minidish and for the phone line, just get yourself an extension reel for the duration of the installation. | |||
| | #9 | |||
I'm assuming I could use the same system with a sky box? Reading some other threads it seems that with only having the single Inverto LNB, it would be a waste to pay for a sky+ box and should go for the basic box, is that right? Parking it on 28.2E each night would not be a problem. Thanks Frank | |||
| | #10 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Yes, but if you are going to use the LNB loopthrough on the Technomate, you will have problems, as even in standby, the digibox still powers the LNB, you really need a separate dish, or at the very least, a twin LNB. But if you are going to go for Sky, why not go the whole hog and get Sky+, it is leaps and bounds better than a standard box. . | ||
| connection, sky, telephone |
