Looking for 'hackable' DVRSky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally. | |
| Member Join Date: 30-09-2005 Location: UK
My System: 1.2 Metre Dish, Channel Master H-H mount, ACME Actuator, Skystar2, PIII-600MHz |
Hello, I am looking for a DVR which can be used to digitise VHS cassettes and also for general use recording (analogue) output from my Sky box. I say 'hackable' because I would like to be able to get into the system so I can transfer recorded files onto a Linux server and use them with XBMC. I don't mind if the 'hacking' is technical, so long as it's possible, and I want to be sure that when I order the unit there will be some exploit that allows me to get the files into some format I can use from a PC. If the unit had an ethernet interface that would be a plus. I would like good video quality, not so bothered about file size on the disk. Can anyone advise me? many thanks, biff. | ||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
| Considering the low quality of VCR compared to DVD, I am not sure if I would personally bother to convert VHS cassettes to any other format, but you probably have your reasons. When you say Digitize, which STANDARD formats are you after? With a good DVR (I use Pioneer), you can convert a VHS cassette directly to a DVD using the A/V SCART or RCA cable (Composite video) and then take the DVD, insert it in your PC DVD Drive, use Nero Application to extract, edit and save the VODs to other formats like *.mpg With a Dreambox (Linux receiver with Ethernet interface), you can then upload the files to the internal HDD and probably use it as a linux server. Many members use a Dreambox to open Sky channels and record directly to it's internal HDD, with the possibility to extract the *.ts files to a PC. So perhaps you can use this method also instead of using a Sky Box. | ||
| | #3 | |||||
My System: 1.2 Metre Dish, Channel Master H-H mount, ACME Actuator, Skystar2, PIII-600MHz | Yeah.. I deliberately left that out :-). So long as I can play back on a PC (now) I believe I am probably OK for the future, what with virtual machines and so on. MPEG2, DivX, xvid, SWF or whatever would be fine. I'd like to avoid archiving in MJPEG, because that probably would take a huge amount of space though. Or did you mean tv standards? I only need PAL input.
thanks, biff. | |||||
| | #4 | |||
| Specialist Contributor Join Date: 07-05-2008 Location: NW, Ireland
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters |
You mentioned recording from a sly box in your 1st post, If its just FTA programing you are interested in (No card) , then the DM-600 can do that. | |||
| | #5 | |||
My System: 1.2 Metre Dish, Channel Master H-H mount, ACME Actuator, Skystar2, PIII-600MHz | | |||
| dvr, hackable |
